12-12-2022, 02:04 PM | #1 |
Rear x frame 1961 removal?
Curious… maybe a dumb question causing the frame to be weak but has anyone cut the rear part of the x frame out behind the carrier bearing , then boxed the frame rails running back and boxed the center support cross member to stiffen it up. This would eliminate arms hitting when slamming the truck? Any thoughts
Posted via Mobile Device |
12-13-2022, 03:13 PM | #2 |
Re: Rear x frame 1961 removal?
It's not necessary. Get blocks to correct trailing arms in their arc. I went with Porterbuilt arms with 2" drop built in.. they also have 3". Adjustable to help center axle. They have a bridge notch or full rear kit.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
12-14-2022, 08:28 PM | #3 | |
12-14-2022, 10:19 PM | #4 |
If you haven't had a chance to check out SkinnyG's build, I think you could find some valuable information regarding the X frame there. Follow this link: https://67-72chevytrucks.com/vboard/...d.php?t=756182 Page 3 has a lot of frame work
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-15-2022, 08:20 PM | #5 |
you might have to call to get just the bridge. I made my own pipe notch. I went with a 2 piece driveshaft on the shortbed because clearance issues. Look at my build. I don't need to drop more. I have 2" left after shocks bottom out.
12-15-2022, 08:29 PM | #6 |
Pic
12-15-2022, 08:32 PM | #7 |
Mater
