Old 12-14-2022, 09:25 AM   #1
Hotrod1952
72 Door panel install help please
Anyone have a sketch or drawing showing how the handle and crank pieces go in a 72 door? When I got my truck it had no interior. Wondering if I need foam spacers, springs or plastic washers & I see the plastic panels have an escutcheon on them.
Hotrod1952 is offline   Reply With Quote
Old 12-14-2022, 03:07 PM   #2
Peanut74
Re: 72 Door panel install help please
Here is what I found in my factory assembly manual. Is this what you were looking for?
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 12-14-2022, 03:38 PM   #3
Hotrod1952
Thanks I looked at that too. But 72 has plastic door panels.
Old 12-14-2022, 04:49 PM   #4
Thealien
Thealien's Avatar
You said you needed help installing the door and window cranks and associated parts. The way those parts mount is the same from 1967 to 1972. The 1972 door handle and window crank stub out sticks out slightly further to accommodate those plastic door panels. But everything works the same otherwise.
Those pictures should help you with the assembly except for the installation of the door panel which in 72 is held on by plastic clips.
Old 12-14-2022, 06:04 PM   #5
72c20customcamper
72c20customcamper's Avatar
Other than the handle clips there is nothing else involved . At least that’s the way my truck is .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 12-15-2022, 11:07 AM   #6
Hotrod1952
Smile Re: 72 Door panel install help please
Ok good to know. Thanks Guys.
Old 12-14-2022, 04:02 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Go LMC website and look at there 67-72 parts catalog. Its great for installs.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 12-15-2022, 02:21 PM   #8
72SB
+1 on post #6. With that said IDK if originally there were any plastic stepped washers for the window cranks pn my 72 C10 like my 67 Camaro has. Given the door panels are hard plastic
...but the illustration post in # 2 shows item "7" goes between panel and window & door handle...so that may be the plastic washer thing similar to what my 67 Camaro uses...if not the same
72SB is offline   Reply With Quote
Old 12-15-2022, 08:57 PM   #9
howzzzit
howzzzit's Avatar
Follow this link on the forum. 72 panel is toward the end. Only 1090 pages!
A big thank you to CS1972 for posting this manual.
https://67-72chevytrucks.com/vboard/...d.php?t=833705
howzzzit is offline   Reply With Quote
Old 12-16-2022, 12:05 AM   #10
davischevy
davischevy's Avatar
72 has a thick foam washer between the door and the door panel.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-16-2022, 12:23 AM   #11
72SB
what I found on interweb...
these say 60-66
https://www.cjponyparts.com/gasket-s...-1966/p/IHSG1/
and these for 67-72
https://www.amazon.com/dp/B07S5CXZCB...v_ov_lig_dp_it
Old 12-16-2022, 12:32 AM   #12
davischevy
davischevy's Avatar
https://67-72chevytrucks.com/vboard/...d.php?t=840266
other Larry
Old 12-16-2022, 10:03 AM   #13
Hotrod1952
I am no expert, I'm just the guy asking questions. But, what I think I have figured out is the 72's do not use the escutcheon. Just the plastic stepped washer. If you have wood grain panels then the foam goes in between the panel and the wood grain part.
Old 01-05-2023, 03:02 AM   #14
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I can't speak too much for 72. The escutcheons differ from 71, same perhaps the flush washers. Seems there's a plastic washer or two.
You might contact Wes at Classic Heartbeat, he knows the doors for certain and can get the parts.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-08-2023, 09:46 AM   #15
CUSTOM/10
CUSTOM/10's Avatar
I believe these are what your looking for.
Gary
https://www.classicindustries.com/pr.../20393850.html
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 01-08-2023, 07:50 PM   #16
72SB
Dorman makes them, Amazon has them
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
