![]() Join Date: Nov 2022
Idle intermittently high
Edit: Here's my engine https://www.summitracing.com/parts/m...xoCKRsQAvD_BwE
Hi. I bought a 1971 C10 GMC and had a 350 crate engine put in. When you first start it it idles at a high rpm and if you try to put the truck in reverse or drive while it's doing this, it dies. Letting it sit and idle at a high rpm for 1 or 2 minutes sometimes let's it move to a normal rpm and sometimes not and it will just continue to idle high. Tapping the gas also sometimes moves it to a normal ramp but sometimes not.The out of state mechanic says that this is normal and is trying to get out of doing warranty work. Honestly I give up on him anyway and don't want to drive a state away for fixes. I'd rather fix it myself. What could be possibly causing this high idle? Last edited by K10-Kansas; 12-17-2022 at 09:36 PM. Reason: Added what my engine is |
Re: Idle intermittently high
First thing, welcome to the forum!
Now let the fun begin! Pics of your motor always help. What 350? From where? Who was the builder? What carb? What intake? There’ll be lots of questions. Did I mention pics? |
Thanks, happy to be here. Sounds good, I'll update the post when I get home from work today.
![]() Join Date: Nov 2013
without any specific information...
make sure the throttle spring has enough tension to keep it closed.... check the choke and high idle setting and also make sure there is no binding of the choke linkage.... it should idle high for a few minutes at cold start then back off as the engine comes up to temperature..... again.....more info is necessary for internet troubleshooting....maybe even a short video while it's doing it...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
![]() Join Date: Mar 2015
If the carburetor is used the issue could be worn butterfly bores.
I would also recommend disconnecting the carburetor linkage and confirming the linkage moves smoothly. Lubricate any pivot points. |
#6 | |
![]() Join Date: Nov 2020
Does it have an electric choke? If so, check to make sure the wire is connected and has power. The electric choke can be adjusted by loosening the screws and turning the mechanism to increase or decrease how "quickly" it opens.
![]() Join Date: Apr 2016
You probably have a fast idle spring and lever setup on your carburetor that is tied in with the choke. On my Quadrajet for example, the lever has several steps with varying amount of faster idle. When I press the gas pedal before start and if it is cold outside, the lever moves to the maximum position. Then I start the engine. As the engine warms up, if I press the gas pedal, when I release the gas pedal it may move to a lower step and idle a little slower. If I don't touch the gas pedal it will stay on high idle forever. When fully warmed up, the last step on the lever is used when releasing the gas pedal, which is normal idle. Getting to full warm up depends on the weather. It may take more than a very brief and light tap of the gas pedal to make it go down one or several steps. I am able to drive my truck, and I believe it is normal to be able to drive, when it is fast idling and when still warming up.
#9 | |
#10 | |
Man I feel old right now.... |
#11 | |
It has been 30 years since I've driven an older vehicle but I don't remember my 72 nova acting this way back in 92. Thanks for your help on this. I wish I could test it more but right now am putting in a complete wiring harness. ![]() |
New motor!
Was it broke in correctly? Do you know the break in procedure? 2000 rpm for 20 minutes scenario! |
#13 | |
Nah! You’re good!
The engine specs where confusing. I had to read a little better to see it’s a roller cam motor. They don’t need the critical break in procedure. Thought you were gonna post some pics of your motor. Prying eyes can see things your mechanic fudged on. |
#15 | |
#16 |
#17 |
OP
You have a BPE motor, excellent motor. There would have been a full packet of info for the motor stapled to the crate it came in. Contact BPE tech dept, give them the ID # of the motor you have (its on DS of block). If the "mechanic" didn't give you the packet BPE has a file on it and can send duplicate. they dynoed the motor, its already broken in I believe they use 600 cfm holly carb. Sounds like you just need some minimal adjustments. If it is an electric choke you need IGN power to it If you have the skills, a vacuum gauge, timing light and a tach (some timing lights have them) will get you dialed in Sounds like the chole is either not working or carb does not have one. Just contact BPE tech and they will give solid advice. That motor has a warranty |
#18 | |
#19 |
Here are some pics of the engine.
#20 |
yes you have a EL choke and I see it is wired....You would have yo meter the wire to see if its is getting 12vdc
However your wiring does look sketchy in general but if you get 12v to it, than it will work On a cold engine you should just hit gas once to close the choke then start with abour 1/2 pedal I would get some plug wire management, so you don't burn one on the headers |
#21 | |
#22 | |
Who Changed This?
![]() Join Date: Jan 2013
OP- I'm not seeing a distribution block/proportioning valve assembly next to the master cylinder. Was it like that when you got it? Or am I just blind?
#23 | |
It’s on the frame crossmember down by the rad. |
#24 | |
Who Changed This?
#25 |
AAW makes a nice kit. While you are on wiring mode, consider a headlight relay harness. Not only will your headlights be brighter, all your lights will be. I got mine from LMC
Takes the full 12vdc load off the light switch |
