Old 12-21-2022, 04:13 PM   #1
kens65fb
Rear tire 20inch fitment ?
Will a 275/40/20 tire fit the rear of my fleetside, it has been lowered 4 inches
4.75 inch backspace
28.7 inch diameter,
If not, what is a good size for a 20 inch wheel in the rear.
kens65fb is offline   Reply With Quote
Old 12-21-2022, 08:56 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Rear tire 20inch fitment ?
Stock 12 bolt or slightly wider axle from a later year truck?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-22-2022, 08:44 AM   #3
kens65fb
Stock 12 bolt rear
Currently using 275/60/15 on the rear, they are tight, but don rub.
Old 12-22-2022, 10:30 AM   #4
SCOTI
SCOTI's Avatar
There's never an exact answer for these questions. What fits on 5 different trucks might have issues on 5 other trucks because of subtle variances. What's the BS on the 15's?
If the wheels are the same width & BS, only the height is slightly different. At only 4" of rear drop, that change shouldn't be an issue.
There can be minor size variances between similar section width tires (275mm), especially when using different diameter combos w/different aspect ratios (40 vs 60).
It comes down to where the new combo will sit relative to where the old was & the amount of clearance the old combo has.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-24-2022, 10:11 AM   #5
kens65fb
Will a 29 inch tall tire be too much?
Old 12-24-2022, 01:14 PM   #6
SCOTI
SCOTI's Avatar
It shouldn't @ only 4" of drop.
To 100% verify, set the truck up w/some jack stands so the rear end is compressed/has weight on it but off the ground. Tape some 2x4 blocks to the tire/s, spin the wheels/tires & see what happens.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
