12-24-2022, 10:39 AM | #1 |
1972 C20 2 wheel drive GVW
I need a few pics of the GVW numbers on 1972 2 wheel drive C20 VIN tags. Your VIN number doesn't need to be in the pic just the GVW. Any help would certainly be appreciated. Happy Holidays!
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
12-24-2022, 12:16 PM | #2 |
Re: 1972 C20 2 wheel drive GVW
Here ya go...
12-24-2022, 01:09 PM | #3 |
Thanks! I need a few more examples y'all
12-24-2022, 01:13 PM | #4 |
Did your truck come optioned with heavy front spring?
12-24-2022, 01:27 PM | #5 |
I'm not sure about the springs, here's a pic of the SPID if that helps....
12-24-2022, 03:52 PM | #6 |
Heavy Springs may have been part of the" Custom Camper Equipment ". Jocko most likely will be able to shed some light on that
12-24-2022, 08:55 PM | #7 |
here's the plate on my 72 big block c-20 with a Dana 60 rear on leaf springs.the build sheet says G50 HVY Rear Spring,no mention of front springs.
12-24-2022, 01:30 PM | #8 |
I’ve never seen a C20 (or K20) that was not 7500 lb GVWR - have had HO and D60 rear axles in them. But who knows. Had a 72 C20 with G50 Heavy Rear Spring and a K20 with G50 Heavy Rear Spring and F60 Heavy Front Spring - both were 7500 lb GVWR.
12-24-2022, 02:25 PM | #9 |
Interesting point jocko, but surely they all can't be 7500lb. AFAIK, if it had all the optional heavy duty equipment, it was rated at the max. 7500lb. For instance, Ford had a 6200lb, 6900lb and a 7500lb version of the F 250 during the same era, depending on the spring build up and tires.
12-24-2022, 02:42 PM | #10 |
Here's another with slightly different as manufactured vs max capability on the rear axle.
12-24-2022, 03:18 PM | #11 | |
12-25-2022, 05:43 PM | #12 |
Its a Truck Thing......
I have 3, 3/4's. Two 71's and a 72. Here are my ratings.
71 Longhorn, 350 eng, HO rear. Leaf Springs 3000 Front 4700/5500 Rear 6700/7500 Total 71 Cheyenne (Mo Door) 402 BB, D-60 Rear, Rear Heavy Coils 3000 Front 4880/5500 Rear 6700/7500 Total 72 GMC 350 eng, SPID Painted over, Has TH350, D-60 rear, Leaf Springs 3500 Front 4700/5500 Rear 6700/7500 Total Both my 71's have readable SPIDS. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" Last edited by 71meangreenc10; 12-25-2022 at 05:49 PM. |
12-26-2022, 02:56 AM | #13 |
It's going to depend on what tires and springs were on the truck when it was sold new.
As you can see here a C 20 could come with one of three gross weight capacities 6200, 6700 or 7500 depending on the wheel and tire combo and the rear springs that it has. That found here in the 1972 Chevy truck PFD from the GM heritage center. https://www.gm.com/content/dam/compa...olet-Truck.pdf
12-26-2022, 12:59 PM | #14 | |
12-26-2022, 12:26 PM | #15 | |
6200lbs - limited by base springs or base tires (3980lbs) 6700 lbs - upgraded rear springs (G50), limited by upgraded rear tires (4880lbs) 7500lbs - upgraded springs (G50), max upgrade tires, limited by rear end (5500 lbs) or other component There are some variations in the "max rear weight at ground" if alternate tire/spring combinations were ordered.
1971 Pontiac Firebird 1971 GMC C2500 |
12-26-2022, 04:37 PM | #16 |
I've posted it on the 47/59 group before but you can find the pfd for most years by scrolling down this list from the GM Heritage center archives https://www.gm.com/heritage/archive/...tion-kits.html
12-28-2022, 12:07 AM | #17 |
I’ve owned 4 different C20’s. The 69 GMC didn’t have the GVWR listed on it’s tag. The others were 6200 GVWR for a 127” wb, 6 cylinder 3 speed and 4.57 gears. A Longhorn 133” wb with 350, SM465 with a 6600 GVWR and a 400/TH400 127” wb with 7500 GVWR.
