Don't like my tall 1st Gear - Do my larger tires make the difference?
Hey Guys, I've mentioned before on another post that I don't like how tall my 1st gear is in my truck. It seems like I have to slip it forever before getting going.
The truck came with 265/70R15 winter tires on it which even by looks appear much bigger than stock. I did the tire comparison chart with stock (225/70R15) and it says the circumference difference is 88.3 vs 93.0 inches = +4.6% difference. In your opinions, do you think if I went back to stock with summer tires that the 4.6% difference would make a big difference on how my first gear feels or would this be negligible?
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
Re: Don't like my tall 1st Gear - Do my larger tires make the difference?
your larger winter tire diameter would have more an impact if your rear gears were high like 2.xx. vs. 3.42 and lower (3.73) rear gear not much of a difference
what rear gear do you have? |
#3 | |
I plan on changing the rear end fluid and gasket soon so I'll have to check when I'm in there. It will be stamped on the gear correct?
![]() Join Date: Feb 2016
Yes. Like below.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
So how do those #'s decipher into the gearing code?
Who Changed This?
![]() Join Date: Jan 2013
Pinion 13 teeth, ring 40 teeth, 40/13 ~ 3.077, usually called 3.08.
#7 | |
The Older Generation
I deleted your duplicate post in the "Projects and Builds" forum. This would be the correct forum for your question.... LockDoc, Moderator .
#8 | |
[quote=jimijam00;9163432]I'll just leave this here...
https://www.youtube.com/watch?v=uU6WJXjZf4Y[/quote Sweet, that's supper easy to calculate that way! Thanks for the video link ![]()
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) Last edited by Yamariv; 01-05-2023 at 06:56 PM. |
OP
My ring gear had the ratio # stamped on it 11:41 (3:73). divide the larger # (ring gear) by smaller # pinon gear)...original gear. The spin tire one revolution and count the turns of DS is easy post 5 ring gear is 13x40=3:08 |
#12 | |
Thanks for everyones help with this! ![]()
Who Changed This?
Make sure to get the right lube when you do this. Some lubes are not appropriate for the old gears like we run.
#14 | |
I had read that some of the old standard transmissions don't like full synthetic because of the sycros so I went dino oil for that but had no idea there were wrong oils for the rear diff
#15 |
Who Changed This?
You'll just have to look at the labels and the requirements. Hopefully someone will chime in with the proper info. I just know that the wrong lube can trash things.
#16 |
My understanding and what I have read and use.
These older manual transmissions should have GL-4 oil. The GL-5 is bad for the brass synchro rings. GL-4, synthetic or not will work. If the container says GL-4 & GL-5, don't use it in the transmission. If the container says GL-5 anywhere on the label, don't use it in the transmission. If the rear end has an open differential, you can use limited slip lube or not, synthetic or not. If the diff is limited slip, then the oil should say that or there are limited slip additives.
'67 GMC 2500, 292, 4spd, AC |
#17 |
OP, if you have a clutch pack type limited slip differential, you do not want to use synthetic gear oil. You use standard gear oil and GM "friction modifier" additive 4 oz bottle
I don't think synthetic otherwise will hurt a rear gear otherwise, but I always use just conventional gear oil |
#18 |
That makes sense! It's just a regular 12 bolt rear end (no limited slip) so I can't see a regular or full synthetic oil hurting anything.
Thanks guys!
#19 |
Who Changed This?
OK, it must have been transmissions that one had to be careful with. Just trying to help.
#20 |
![]() Join Date: Dec 1999
A comment on a fairly recent experience. My new front custom fabricated D60 for my K10 had a tag on it that said not to use synthetic fluid. Open diff as I did not want to spring for a locker at this time. From what I understand synthetic is not recommended for the ARB air locker or from Yukon the gears I am putting the rear as well.
Assuming your gears are 3.73. By my calculations your suggested tire size change would be the approximately same as switching to 4.10 gears. Raise rpm about 90.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-09-2023 at 05:16 AM. |
#21 | |
#22 |
265/70/15 on truck is taller than new suggested original size, 225/70/15 by about 2" if I recall. A smaller tire will lower gear ratio. Numerically higher but is a lower gear. Smaller tire equals more revolutions per mile.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#23 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#24 |
My first gear is the other way around, maybe tall is the wrong word but it takes in my opinion way more clutch slippage to get it going and I'm doing 5-6 mph before I can let the clutch fully out. It's not a granny gear at all, the other way around which is pretty annoying for me
#25 |
On Jan 5, post #13, you said you would check the rear end ratio.
Start there, before you before you worry about anything else.
