01-08-2023, 02:25 PM | #1 |
Cabin noise
Today I finally got to take my 66 c10 out on its maiden voyage after a lot of changes all at once. I had it around the block twice to test a few things but today was its first trip up to highway speed and I cant say I wasn't a lil nervous. I lowered it, added front disk and power brakes, all new brake lines, new tire and wheels, all new steering and the freshly rebuilt rear with higher gears and I was mighty pleased nothing went wrong.
But to the reason for starting this thread is cabin noise. I guess I never cared or paid much attention until today when I was peak awareness listening for any shenanigans. My blower motor sounds like its grinding coffee so I guess a new motor and hamster cage is in order. I'm moments away from ordering a new engine fan and accompanying clutch so I can get rid of the constant typhoon the direct drive one produces. The one thing I'm questioning is the spedo makin a little racket under the dash. My question to the gurus is to eliminate the noise do I need to look at the speedometer itself or would the cable itself be the culprit? Oh I'll also be adding deadmat when I do the floor and rockers very soon to take care of some road noise |
01-08-2023, 03:46 PM | #2 |
Re: Cabin noise
For the speedometer noise, disconnect the cable going into the back and spray some white lithium grease down the cable. You can also pull the inner cable out and spray all along it. This is the easiest fix, so I'd suggest trying this first. I don't think it is a good idea to spray into the back of the speedometer.
01-08-2023, 03:58 PM | #3 | |
Re: Cabin noise
01-08-2023, 05:13 PM | #4 |
Re: Cabin noise
There is a proper dry powder graphite speedo lube that you should use for cables, allegedly it does not "gum up" over time like a liquid or grease does.
I'd probably use a penetrating fluid of some sort, "proper" be danged (grin).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
