Old 01-11-2023, 05:59 PM   #1
howzzzit
howzzzit's Avatar
Bed bolt torque
Think I read this correctly in the assembly manual. 15-24 lbs torque for C10 steel bed floor? Split it and go 20? I don't want to over tighten and suck in the bolt heads and on the the hand have the bed come loose.
howzzzit is offline   Reply With Quote
Old 01-11-2023, 08:22 PM   #2
kwmech
Re: Bed bolt torque
Standard bolts, I just tighten them until the lock washer collapses and a little snug after that and call it good.
Stainless bolts are a little more finicky to keep from galling unless you use a dab of grease or anti-seize on every one (which you almost have to do)
Old 01-15-2023, 02:07 AM   #3
howzzzit
howzzzit's Avatar
Re: Bed bolt torque
Thanks. I did like you said. Tightened until washer collapsed. Gave it a little more until my elbow clicked.
Old 01-15-2023, 03:23 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Bed bolt torque
What torque does your elbow click at?
And - is it adjustable?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
