Old 01-05-2004, 10:05 PM   #1
cheyguy
cheyguy's Avatar
Question Trailing arm question for the experts.
The pictures don't look quiet as bad as they really are. The question is, Should I
a: Scrap'em and find some replacements.
b: Por-15'em and let them ride.
c: Use them for now, but replace them down the road.
d: other
I'm currently preping the frame and suspention for Por-15 (when it warms up a bit) and don't want to put more time into these if they're not worthy. Thanks in advance, Mike
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
cheyguy is offline   Reply With Quote
Old 01-05-2004, 10:13 PM   #2
6772king
6772king's Avatar
i used a set worse than that i just got all the cancer out of in between them then stich welded them. just my 2 cents but i never had any probl.
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 01-05-2004, 11:38 PM   #3
72superBB
72superBB's Avatar
Mine are like that. Thought I could not fix them. What is stich welding?
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 01-05-2004, 11:45 PM   #4
dinnut
dinnut's Avatar
where exactly are these on the truck? i know in the rear... but what do they do? i really dont know!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-05-2004, 11:50 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dinnut, they are the link between the frame and the rear end. They allow the rear end to pivot up and down as the suspension moves.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-05-2004, 11:59 PM   #6
Gee_Emm
I would say use them and keep an eye out for some better ones, they are somewhat hard to come by though.
Gee_Emm is offline   Reply With Quote
Old 01-06-2004, 12:12 AM   #7
cheyguy
cheyguy's Avatar
Thanks for the opinions guys.
6772king- How did you get the rust out? I've grinded some, wire wheeled some, saw-zawed some, even tried the beat it out with a screwdriver method all with a very little success for the time spent.
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
Old 01-06-2004, 12:33 AM   #8
JQ-72
JQ-72's Avatar
I've got some for sale. Sent you a p.m.
Joshua
JQ-72 is offline   Reply With Quote
Old 01-06-2004, 12:58 AM   #9
Martin64
Martin64's Avatar
.........sand blast 'em
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 01-06-2004, 12:59 AM   #10
Chevyguy111786
Those would be Trailing arms. I have a set for sale for $50 obo, if your interested.
Chevyguy111786 is offline   Reply With Quote
Old 01-06-2004, 04:22 AM   #11
doughby82
doughby82's Avatar
i say if you feel uncomfortable with them just replace them.it will save you from doing it later
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 01-06-2004, 09:48 AM   #12
jamis
F.A.S.T. president
jamis's Avatar
I would replace them, you can get decent used ones from someone else for a reasonable price. If you want to slavage them
the best way to do it IMO is to drill out the welds separate the halfs and grind the inside, then just weld them back together by running a bead in the groove where they join. You can also weld a plate to the upper and lower sides to make it stronger.
jamis is offline   Reply With Quote
Old 01-06-2004, 07:50 PM   #13
6772king
6772king's Avatar
I beat them with a hammer to get the most of it out them sandblasted the rest
