Old 01-18-2023, 03:55 PM   #1
K10-Kansas
K10-Kansas's Avatar
Classic performance parts steering wheel crooked
Does your gear selection indicator sit at 12:00? I just installed my CPP column and my indicator is sitting at 12:30. The notch in the steering column shaft that sits over the protruding notch in the brake pedal steering column mount housing, those notches don't line up centered between the shift indicator screws. Are everyone's shift indicators slanted to the right?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 01-18-2023, 09:39 PM   #2
best view
Re: Classic performance parts steering wheel crooked
Wow that’s hard to look at
best view is offline   Reply With Quote
Old 01-19-2023, 09:00 AM   #3
I feel like I'm eating a taco
Old 01-19-2023, 09:49 AM   #4
HO455
HO455's Avatar
Yep, that's cockeyed.
RIP Bob Parks.
Old 01-19-2023, 11:28 AM   #5
68 C10 Driver
Just out of curiosity, what does it look like on the other side of the firewall at the bracket?
68 C10 Driver is offline   Reply With Quote
Old 01-21-2023, 11:24 AM   #6
K10-Kansas
K10-Kansas's Avatar
Here's the engine bay side
Old 01-21-2023, 07:20 PM   #7
clay68c10
clay68c10's Avatar
It should be straight up at 12:00
The rectangular holes in the column tube should line up with it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-22-2023, 09:04 AM   #8
K10-Kansas
K10-Kansas's Avatar
I called CPP and they say they are looking at their columns to see if there is a problem. I called IDIDIT and they said their columns don't have this problem because the user drills the shift indicator holes themselves. I called local IDIDIT reseller and he says he cuts the brake housing nipple off to make the CPP columns straight. I'm not doing that. I imagine I'll get a replacement CPP column or I return it and get an IDIDIT column.
This has been a ton of work and hassle with the issues with the CPP column. I feel like they owe me $500 in labor costs.
Old 01-23-2023, 04:34 PM   #9
Montierth
Montierth's Avatar
I have been looking at the CPP tilt column due to the price and their saying it is all new. The shift indicator lining up right is one of the reasons I would want to change out my current stock column. Did CPP ever get back to you? Sounds like paying the bigger money and going with IDIDIT is the way to go for me.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 01-23-2023, 08:03 PM   #10
68 C10 Driver
I was going to say loosen the column clamps on the firewall and under the dash and rotate the column counter clockwise, but that would put the shifter in an odd angle. Looks like that column you have is actually defective.
I have seen the IDIDIT units and they look really nice...or get a used GM tilt column and refurbish it.
Old 01-23-2023, 09:57 PM   #11
K10-Kansas
K10-Kansas's Avatar
The only way I could rotate the column is if I ground off the nipple in the "firewall-brake pedal-column support housing".
Old 01-23-2023, 09:55 PM   #12
K10-Kansas
K10-Kansas's Avatar
I emailed them again and no reply.
Old 01-27-2023, 12:33 AM   #13
Casper42
Casper42's Avatar
hum. its odd indeed. Perhaps your signiture might explain something about the fit:
1971 GMC C10 cab. 71-72 Chevy grill. Maybe a 77-78 K10 frame. Long bed cut to short bed step side. Manual changed over to automatic R700 4 speed
It seems your truck has had a LOT of work. Perhaps this is not a CPP issue. hum
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-27-2023, 09:12 AM   #14
K10-Kansas
K10-Kansas's Avatar
I think the center nipple in the brake-clutch-steering support for all trucks is centered. Mine is centered. I confirmed that the notch cut into the steering column that the nipples set into is offset from the 2 holes that hold the gear selection indicator for the classic performance parts steering column hanging on the wall at LMC just like the CPP column I installed is offset. Since their columns are offset and C10 nipples are centered then the columns would look offset. A fabricator i called also confirmed that he cuts the nipple off C10 trucks to get CCP columns to sit straight.
Old 01-27-2023, 10:48 AM   #15
Montierth
Montierth's Avatar
I am trying to picture what you mean by cutting off the center nipple in the brake-clutch-steering support. Is this inside the cab or under hood? Is this on the column or on the truck that you are having to cut? Just curious. Thanks
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 01-31-2023, 10:54 PM   #16
K10-Kansas
K10-Kansas's Avatar
Here is the nipple I was referring to.
Old 02-01-2023, 08:33 AM   #17
K10-Kansas
K10-Kansas's Avatar
I need some pictures to show the CPP representative that the indicator housing should be centered. Could you all post some pictures in this thread?
Old 02-01-2023, 05:50 PM   #18
Montierth
Montierth's Avatar
Ahh I see. Now I gotta look at mine. Assuming the support/brace would have the nipple regardless if automatic or clutch truck.
Maybe a longshot but I think I saw in a previous post your dash was bent. Would that play into this at all? Just a thot?
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 01-27-2023, 09:33 AM   #19
Column fitment only involves the cab and all columns interchange in 67-72 trucks
Old 01-27-2023, 12:57 PM   #20
6600DURAMAX
6600DURAMAX's Avatar
subscribed
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 01-31-2023, 07:20 PM   #21
K10-Kansas
K10-Kansas's Avatar
CPP is claiming that all C10 trucks have offset gear selection indicators
Old 01-31-2023, 09:55 PM   #22
best view
Now that’s funny I’d tell them the experts in this truck club are seeing this and all potential customers
Old 01-31-2023, 10:27 PM   #23
Johnl48
Tilt column I got here from Don D lined up perfectly. No issues
Old 02-09-2023, 05:37 PM   #24
K10-Kansas
K10-Kansas's Avatar
Hi. Was it a CPP column? Do you still have the nipple on the brake assembly housing?
Old 02-01-2023, 09:40 AM   #25
I'd tell Moises Perez to let me talk to your QC Dept. so they can convince me as easily as they convinced you, with a poor and incorrect answer! Oh but wait, the customer in the store confirmed it. My bad. The thousands of people who think the indicator should sit square, based on the view from the driver seat or their truck, are wrong. Or, maybe he should have asked that customer if his column was a CPP as well.
