Old 01-24-2023, 03:20 PM   #1
mschwader
Header Advice
Hi! I have a 327 that I need headers for. Motor isn't currently in the truck yet. Looking to get a head start on looking for them in the event what i need is on back order. What should I be looking for? Do I need long tube or block huggers? I am not looking to do much for custom fit. Just need something to go in with no modification or minimal modification to make work. I have a TH 350 Trans and I kept the Torsion Bars. Thanks in advance.
mschwader is offline   Reply With Quote
Old 01-24-2023, 04:26 PM   #2
forestb
forestb's Avatar
Re: Header Advice
What year of truck?
forestb is offline   Reply With Quote
Old 01-24-2023, 05:26 PM   #3
mschwader
Re: Header Advice
Originally Posted by forestb View Post
What year of truck?
1962 - Its a C20. I swapped to disc all around, put a new rear end in, and rehabbed the front end.
Old 01-24-2023, 05:22 PM   #4
Arne
Arne's Avatar
Re: Header Advice
My '64 came to me with block huggers on a 305. They fit nicely, no interference with anything. But I'm not familiar with the torsion bar suspension, so I don't know if there would be different choke points.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 01-26-2023, 12:47 AM   #5
moonshinerC10
Re: Header Advice
Block huggers will be the easiest headers to install with good clearance for everything. I have 1-7/8 hooker mid lengths on mine. I went with mids because I wanted more ground clearance. I will say I don't think I would use 1-7/8 again. It's a major pain to get to the header bolts.
moonshinerC10 is offline   Reply With Quote
Old 01-30-2023, 11:37 AM   #6
SCOTI
SCOTI's Avatar
Re: Header Advice
1 7/8" mid-length headers for what size motor?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-26-2023, 01:47 AM   #7
Accelo
Accelo's Avatar
Re: Header Advice
Automatics are easiest to deal with when installing headers. You mentioned the transmission type is a automatic. A lot easier and you have more options with automatic. Shorties are also easier to install and clearance most everything. Long tube are king in the HP races. Often you have to relocate the shifter linkage to clear even the shorties. There is a kit that comes right off the column and directly to the shift linkage on the transmission. Where you run the exhaust makes a difference also.
I wouldn't get to far ahead of myself on the purchase. They will not be returnable if you wait too long to try them. We have all been burn on that one.
Cheers
Accelo is offline   Reply With Quote
Old 01-26-2023, 11:01 AM   #8
verdell
verdell's Avatar
Re: Header Advice
I've had really good results with any of these on my sbc, TH350 or 700R4, lowered torsion bar C10.
https://www.hedman.com/truck-headers...7&ModelID=1998
verdell is offline   Reply With Quote
Old 01-30-2023, 05:50 PM   #9
Bushman66
Re: Header Advice
I have these on my 66 4spd truck, they fit perfectly. No issues with them at all.
Bushman66 is offline   Reply With Quote
Old 01-30-2023, 07:06 PM   #10
Arne
Arne's Avatar
Re: Header Advice
The old school exhaust guy who worked on my truck thought mine were these:
https://www.hedman.com/product-detail/68500
- Arne
覧覧覧覧覧覧
