Old 01-29-2023, 09:57 PM   #1
Auctioneerhere
Door Glass on a 61
I plan to replace the door glass I have with new glass. I see the kits of 4 tinted windows for a couple hundred dollars.
Did anyone try it? Did you have to reuse the old track / metal where the window slides on the rollers / run channel?
Auctioneerhere is offline   Reply With Quote
Old 01-30-2023, 08:36 AM   #2
G8rN@te61
Re: Door Glass on a 61
it just depends on how yours is operating. Its a royal PITA.
G8rN@te61 is offline   Reply With Quote
Old 01-30-2023, 11:16 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
My original glass came loose after 50+ years, but I was able to re use everything. If you can, pull the old glass first, inspect the metal parts, then determine if they are reusable or not. If they aren't heavily rusted, you can just put the new glass in the original metal parts
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-31-2023, 01:15 AM   #4
SkinnyG
SkinnyG's Avatar
If the glass is framed, you will want to buy new barrel nuts in advance.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-31-2023, 11:34 AM   #5
Auctioneerhere
Good advice, I am going with the glass that is not framed. The ones I took out were framed & heavy. This is a pulling truck, so every lb. saved matters.
