Old 03-03-2023, 09:23 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
PS Inverted Flare Fittings - 5/8'' -11/16'' to AN
Man I've struggled for the last hour trying to find the right power steering box fittings - running hydroboost setup and I'm looking to run some ptfe black hose.
I am looking for the two ps box fittings - I believe they are 11/16''-18 IFM - Inverted Flare Male and a 5/8''-18 IFM. I can find the straight style fittings but those will not work due the clearance of the inner fender.
What i need ( or believe I need) are 90 degree fittings that come off the box but I cannot for the life of me find them.
Any help guys ?
Picture is just because everyone likes pics ...............
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-04-2023, 12:36 AM   #2
Classic Bowties
Always on the hunt...
Re: PS Inverted Flare Fittings - 5/8'' -11/16'' to AN
^ ^ ^ We are no help on the aftermarket style AN fittings for the style of hose that you are wanting to run, but we did just happen to finish up a P/S conversion on a customers ride and have a few pics to share detailing the OE style hose fitting bends and tight inner fender to hose clearance issue at the p/s gear. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 03-04-2023, 03:47 AM   #3
Richard
Maybe something like this would work for you with the straight fittings? https://www.ebay.com/itm/28357639929...Cclp%3A2047675
Am using -6 hoses myself on all lines except res to pump return which is -12. From my initial observation the standard -6 90 degree hose ends will work out fine in my case.
Richard
Old 03-04-2023, 10:23 AM   #4
6600DURAMAX
Richard - I agree those would work if they had an inverted flare on the end however that is what I am struggling to find. I'm surprised there isn't more options for inverter flare fittings in a 90 degree .....
Classic Bowtie - nice work - I wonder if you could make you metal line just like you have it but once past the inner fender put an AN flare fitting on the end ??
Old 03-06-2023, 01:13 AM   #5
Richard
Understand I said to use them with the straight inverted flare adapters. Just looking at pic posted, top of steering box looks 1.25-1.5" to top of frame. If those fittings threaded right into box the lines would not go over the frame. Bet the combo would get the -6 lines real close to top of frame.
Richard
Old 03-06-2023, 10:16 AM   #6
6600DURAMAX
Forgot I had this flaring kit - might try to make some up if I can find some 3/8'' tubing lying around
Any you are correct about 1-1/2'' plus a little ......
Old 03-04-2023, 11:58 AM   #7
Accelo
Accelo's Avatar
I purchased the factory hose and cut the rubber part off. Then attached the new hose to the factory bent steel fitting. First attempt was using a crimping tool for air conditioning.
That one leaked, so I ended up using a hydraulic flair tool. The biggest issue was finding the sleeve that is crimped. I ended up making on the lathe. I believe the only reason the air-conditioning crimp didn't work was because I machined the ferrule a little too thick on the wall diameter. Yes, it was a PITA. Something I just couldn't find. Took me a week to get it leak free.
Accelo is offline   Reply With Quote
Old 03-04-2023, 06:47 PM   #8
6600DURAMAX
Classic Bowtie - Can you make the hose with a 18Mx1.5 end on it for my hydroboost ? I really was wanting AN fittings and PTFE Black hose to match everything else but if rubber will work I'll settle for that. I would have you make the other
Old 03-04-2023, 06:52 PM   #9
6600DURAMAX
Any one by chance know the height on this - hate to spend the dollars if its too tall ....
Old 03-06-2023, 10:27 AM   #10
NJ68stepside
Call these guys up. I bought all my stuff through them. It’s a real pain in the ass. But it’ll be worth it in the end.
They have bare hoses and ends. So you can make your own. That’s what I did.
https://www.anplumbing.com/
Please be patient. I’m a ford guy. This is my 1st Chevy.
Previous cars:
1973 mustang convertible
2003 mustang Mach 1
Now building resto mod 68 C10 step
NJ68stepside is offline   Reply With Quote
Old 03-08-2023, 12:47 AM   #11
PowerdbyChevy79
PowerdbyChevy79's Avatar
Thats a great site..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 03-08-2023, 09:32 PM   #12
NJ68stepside
They are! I made a order of power steering hoses and return lines, they called me up and redid my order and saved me a lot of money.
Previous cars:
2003 mustang Mach 1
