Old 03-21-2023, 01:47 PM   #1
oldtrux
oldtrux's Avatar
Tach help please
Anyone familiar with this tach? 6-8 cylinder??
oldtrux is offline   Reply With Quote
Old 03-21-2023, 04:18 PM   #2
scottofksu
scottofksu's Avatar
Re: Tach help please
I can't offer much in the way of which engine this tach will work for, but I can say it looks to be a later unit if its factory (i.e., without a transmitter box).
I did find this post that includes a picture of an OE-1 by member 1963c-10. Not sure if they are still on here or if that was their tach that was pictured. I believe what you have is a V8 tach, but I am not certain.
https://67-72chevytrucks.com/vboard/...=392461&page=4
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 03-21-2023, 04:57 PM   #3
oldtrux
oldtrux's Avatar
Thank you,I appreciate the help!!
Old 03-21-2023, 05:04 PM   #4
oldtrux
oldtrux's Avatar
I guess my next quest will be can i make it work with an hei dizzy? Nothings easy lol
Old 03-21-2023, 05:44 PM   #5
Arne
Arne's Avatar
Take a look at this. Pretty sure the owner (Bob Ashlock) can set you up, regardless of what the original tach was for.
https://ashlocktech.com/tach-adapt-1
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 03-21-2023, 08:18 PM   #6
oldtrux
oldtrux's Avatar
Thank you!
Old 03-23-2023, 12:01 AM   #7
Nanook
Nanook's Avatar
100% agree...just purchased one of his units and I am using an original 8 cyl tach with a 6 cyl. (It also will work with the HEI)
Nanook is offline   Reply With Quote
Old 03-23-2023, 11:14 AM   #8
MikeN
MikeN's Avatar
If that tach works with a points-type distributor, it should work fine on an HEI. There is a TACH terminal on the HEI, just run a wire there from the DIST terminal on your tach.
MikeN is offline   Reply With Quote
Old 03-23-2023, 11:19 AM   #9
oldtrux
oldtrux's Avatar
Oh that would be nice! I will give it a shot!thanks for help
Old 03-23-2023, 01:16 PM   #10
oldtrux
oldtrux's Avatar
Ok,so I reached out to Bob at ashlocktech and he told me I should be fine with my DUI HEI dizzy. He went out of his way to research my dizzy to find out! As was mentioned above what a super knowledgeable and nice guy!! Thanks so much for the great info.
Dan
