04-01-2023, 02:41 PM | #1 |
The 'Optional' yellow and black wire on a Current Performance Harness
Evening all,
Still chipping away at my LS swap and now have stumped myself. Quick bit of back ground Using an LM7 out of a 2005 Silverado and a T56. The harness is from Current Performance and was originally set up for a 4L60E. I have de pinned the auto part of the harness and removed it. I have had the engine running outside the vehicle just using the switched power (pink) wire - ignored the yellow and black wire which is the cranking signal wire. Now I have got the engine in my truck I have a question. Do I need to run the cranking signal wire? The documentation from Current Performance says it is 'option' and says the following re manual gearbox "On vehicles with manual transmissions or automatic transmissions without a neutral/safety switch, this wire should be routed through a clutch safety switch, or shifter mounted switch to prevent the starter from operating in gear" As I have been driving manual gearbox vehicles since I was 9 I trust myself enough to not start the vehicle in gear unless I want too! Think I have answered my own question. I can delete it but would appreciate the sanity check from you bright sparks! Thanks, P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
04-01-2023, 04:37 PM | #2 |
Re: The 'Optional' yellow and black wire on a Current Performance Harness
Back in the day we used to jump the clutch switch so you didn't have to push in the clutch to start. So I would say no not needed.
04-02-2023, 06:59 AM | #3 |
Yea, that was my thinking.
Of course I have fully wrapped the loom so a quick snip with the side cutters is on the Cards! P.
04-03-2023, 10:19 AM | #4 |
I watched a guy in a '41 Willys gasser start it in gear at a car show once, went right into the car in front of it... Only takes one moment of inattention...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-05-2023, 12:18 PM | #5 |
seems easy enough to wire up the correct way....
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
04-07-2023, 06:36 PM | #6 |
If I had the clutch switch I probably would but, as I don’t pretty sure I can do without it….
P.
