Floor shifter for Saginaw 3-speed '87.
Hello all. I'm in the process of getting my '87
![]() At this point I've pretty much given up and resigned myself to cutting a hole and going with a floor shifter. Here's the thing: I'm trying to do it on a budget and don't want to spend $500 on a Hurst Mastershift for a trans I might not keep in the truck (I want to keep it a stick but might eventually go with a 4 or 5 speed). I've been looking on FB marketplace and have found quite a few factory 'ITM' shifters for Camaros/Firebirds with all linkage for $100 or less. That's more budget friendly. Has anyone on here used one of these? Should I go for it or run from it? Curious to know what you guys recommend for other options? Thank you! -Marc. |
68 C10 Longbed
![]() Join Date: Sep 2006
Re: Floor shifter for Saginaw 3-speed '87.
I have the Hurst 3 speed master shift. I switched to 4 speed. Used about 1 year. PM me if interested. I also have the correct Hurst truck handle that goes with it. Lot cheaper than new.
You don’t need to use a just a 3 speed shifter.
A 4 speed one will work. I used a hurst competition plus on my sag 3 speed. Had to bend up some shifter rods for it. |
#4 | |
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#5 | |
Proud Vet that loves the USA
![]() Join Date: Jun 2016
I got some too. Holler if D13 can't help you. Bubba |
Junior Member
![]() Join Date: Jul 2010
Hello,
Apologies for Thread stealing. I'm also looking for 3 speed column Linkage. If Brownsquare isn't interested, I might be. Thanks. |
Thanks guys, it looks like D13 has me hooked up! I just need to get out there and harvest parts! Thank you for all the replies, you guys are great! -Marc.
