Old 04-12-2023, 03:18 PM   #1
custom1970
Member
custom1970's Avatar
Tire size suggestions
I know i've been off a while, but have had some other projects going on lately. So took the truck out last weekend and the steering wheel was shaking like crazy. Got out to check my front tires and noticed that they're coming apart! To bad to even drive to a tire shop. Anyway, since I need 4 new ones (backs got bald somehow anyways) I want to change sizes. I currently have 235/50R17 all around. I've never liked the way they've looked. I'd like to have a taller tire in back, and the same or maybe not as wide on the front. Having a hard time finding the same tire in the sizes i'm looking for. Closest i've found so far is Nitto NT555 275/50r17 for the back and Nitto NT555 225/50r17 for the front. I'm basically wanting to fill that big void over the rear tires. Wondering if anyone has ever done this, or has any other size suggestions.
Thanks, David
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 04-12-2023, 06:00 PM   #2
72SB
Re: Tire size suggestions
look into a 70 series tire if you want bigger diameter.
72SB is offline   Reply With Quote
Old 04-12-2023, 06:40 PM   #3
custom1970
Member
custom1970's Avatar
I used to run 70s years ago when i had 15" wheels, but with 17" wheels 70s get way to tall., too much side wall. Unless I'm doing the calcs wrong. But thanks
Old 04-12-2023, 08:36 PM   #4
They would definitely fill it out better. But your still only abot 29 in tall. If say a 30 maybe 31 inch tall rear tire.
Maybe a 275/60 or 295/50or 295/60 would give you a taller tire in the 30 to 31 ish tall size.
Old 04-12-2023, 10:15 PM   #5
Myself
A 275/55-17 should fill it up nicely.
This is a good tool to visualize the different sizes
https://tiresize.com/comparison/
Myself is offline   Reply With Quote
Old 04-12-2023, 10:47 PM   #6
Mike C
Mike C's Avatar
I run 275 55 17 on the rear and 235 55 17 on the front of my ‘69 and am very happy with that. But nobody makes those tires in a matched set in those size anymore…. My truck is a step side and that’s pretty much max on the back. Your fleet should be able to accomodate a wider tire in the rear of same height (29”)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-13-2023, 02:05 AM   #7
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
I put 245/70-17 tires on the wife's truck. That's about a 30.5 inch tall tire. I think it works well. I'll have to take a picture to post.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-13-2023, 11:03 AM   #8
custom1970
Member
custom1970's Avatar
Finding a matched set is the problem i'm finding. The 70's tires would be great for the back, but i can't find a match for the front. I'd like about a 29" for the rear and approx 10-11" wide. 2" smaller in the front 26-27" and would rather them not be as wide 8-9" as the rear. I'm not sold on the Nitto's. they'd be 27.8 x 10.8 rear and 25.9 x 8.9 front. That gives me about 2" more in back, and about the same in the front, but they'd match. I do plan on doing a spindle drop 2-2.5" in the future, and drop back 2-3" also. Thanks, and keep looking and let everyone know if find another matched set. Thanks, David
