04-28-2023, 07:26 PM | #1 |
1969 International Scout 800 LS Swap
Picked this up a few years ago and it has now officially moved to my garage as a project last week. First things I am doing are putting the springs back under the axles and prepping the LS engine.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 |
04-28-2023, 10:45 PM | #2 |
Re: 1969 International Scout 800 LS Swap
As a fellow IH owner I'll follow. Still undecided on the LS swap though as I like the heavyweight IH engines for some reason. Looks like a clean 800 to start with.
04-29-2023, 01:28 AM | #3 |
Thanks. I want reliability so decided on this route. Here is a picture of it cleaned up and the engine ready to go in. Working on the suspension right now and gas tank next.
04-29-2023, 07:07 AM | #4 |
Very nice..!!..for a Scout, that one looks very solid
The LS will make it a rocket ship What's the plan for a trans and transfer case?
04-30-2023, 12:10 AM | #5 |
Definitely should have some power. I put a BTR Stage 2 cam and new valve springs since I was resealing everything. 4L60E with NP241C transfer case.
04-30-2023, 12:40 AM | #6 |
Cool..!!!!...
04-30-2023, 09:36 AM | #7 |
Yes, very nice!
05-06-2023, 05:41 PM | #8 |
Come clean up MY LS please! Looking good
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
05-31-2023, 11:50 AM | #9 |
Thanks!!!
Thanks!!! Made some progress on the gas door and fuel tank. I need to find the correct hoses. I having been rolling the dice with Amazon with no luck since they dont have measurements listed. I did get one that had the right sizes hoses but not long enough. I have my old engine sold so I need to get it out this weekend.
05-31-2023, 02:31 PM | #10 |
Might look here.i think this is where I've found one before.
https://www.fillernecksupply.com/fue...hose-straight/ I found a place a couple yrs ago that has all kinds of fuel hoses when I was at work and have it saved on my work computer...I had to have a hose I couldnt find anywhere for my C30 when I built the bed for it..they had what I needed.. I "think" the site above is it... I'll verify tonite when I'm at work..
06-04-2023, 02:25 AM | #11 | |
I sold the old engine today and it got pulled. Now the fun begins.
07-22-2023, 01:29 AM | #12 |
Got the radiator mounted. Found an LS Swap Radiator from a 68 impala and had the move the bracket to the front. Also made an adapter plate and used an early 70's chevy truck power booster. Next up is the Nissan Power steering box and the steering column. Then I can start thinking about mounting the engine.
08-04-2023, 11:24 PM | #13 |
Keep posting ��. Truck looks great to start and your welding skills are top notch.
Scott |
08-06-2023, 04:54 PM | #14 |
Not a Scout LS swap but my 98 Wrangler LS6/4L60E I used a Rubicon 241R TC due to its wider TC chain and 4:1 low range. If you don't have it I would add a wide chain kit and SYE to the 241. Also add a CV drive shaft. Maybe also add 1350 u-joints to the drive shaft and axle yoke.
Man I like spending other peoples money. LOL. Good luck with your project. |
08-21-2023, 08:11 PM | #15 | |
08-07-2023, 07:57 AM | #16 |
Proprietor of Dale's Corner
Subbed to watch, nice looking scout
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-21-2023, 08:11 PM | #17 |
Thanks!!!
Thanks!!!
09-10-2023, 01:20 AM | #18 |
Tacked in the motor mounts today. Next up is building the transmission mount then taking it all back out to finish welding up and painting.
09-12-2023, 09:28 PM | #19 |
Good question on the 241. That I don't know.
In the back of my TJ I'm running a 8.8 out of a mid 90's explorer. 4.10 gears with posi. Stock TJ front axle with 4:10 gears. I haven't broke it but my TJ is a mall crawler. Tons of used TJ/JK parts out there for swapping into what ever. I'm wondering if a TJ power steering box might be a some what bolt on? |
09-13-2023, 03:00 PM | #20 | |
09-23-2023, 03:20 AM | #21 |
Getting closer. Have the transmission mount ready to tack together but need to put the transfer case on to make sure the driveshaft will clear it.
05-28-2024, 12:21 AM | #22 |
New ride height. New springs. Switched to spring under with a dana 44.
05-30-2024, 12:33 AM | #23 |
lookin good !!
05-30-2024, 08:52 AM | #24 |
I like it!
10-27-2024, 10:41 PM | #25 |
Mounts are done and engine is in to finally in. Now I should be putting things in for the last time.
