05-10-2023, 05:12 PM | #1 |
go easy please
ok
really struggling with my body work lately ...... this is my first truck and literally do everything on the ground. But I also dont seem to have the knack for it. My thought originally was I could fix the small imperfections with bondo as unless your really good everyone has to do tht anyway. But see my issue below. I know (now) that the answer is probably I should have done this in 1 piece .... and I should have used a piece of machinery that I didnt have to get the bend better - but it seemed ok by standing on it over pipe - but then tightended up after final fitting and stretch of lip. Anyway ...... My question is - is there anyway I can pull the center "divot" out more in center to get the original bend/curve better back into place ..... eg weld something onto the surface and use winch or slide hammer ?? Basically to reduce needing 1/2" bondo in that deep part. *sigh*
FAKKY 57 PANEL BUILD |
05-10-2023, 05:14 PM | #2 |
Re: go easy please
pics
05-10-2023, 06:24 PM | #3 |
Re: go easy please
give yourself a break, everyone starts somewhere and everyone has messed up a panel worse than that getting started. That door is not an easy repair.
Did we see this door before with a prior repair? Unless you have already hammered on it a lot that is probably shrunk along the bead of the weld. There is not enough metal there so it is pulling the door flat. The solution is to get a dolly behind the weld and hammer the bead, hammer on dolly so you get a good anvil like 'ting' and slowly tap your way along the weld from edge towards center. concentrate on the weld bead and and an inch or so either side - the area that was heat discolored after the welding. Push out with the dolly firmly. As you slowly stretch the metal back it will relax the panel and it will curve back out. It will take a bunch of tapping away, but you should see it start to move after a couple minutes. Pounding harder wont help. If you can't get your arm and a dolly back there make up something sturdy that will reach in there, like a truck leaf spring mounted in the vice and slide it through the window slot, balance the door on it and hammer at the point of contact It is also possible that the metal is stretched, but that will only happen if you already hammered it too much or you tried to weld in too large a patch. Welds shrink as they cool, because metal gets softer as you heat it and it expands as you heat it....the soft metal is crushed together with the expansion then it gets hard again faster than it shrinks as it cools. if that makes any sense. We can talk about how to shrink if you find stretching does not work. |
05-11-2023, 03:30 PM | #4 | |
Re: go easy please
This time I went slow and did in sections and allowed cool down Still just ended up looking like that so .... just a bad day after spending 3 afternoons working on it.
05-10-2023, 06:08 PM | #5 |
Re: go easy please
it looks like there has been some shrinkage in the area, probably from welding, so it will need to have some hammer on dolly work across the weld seam in order to stretch the metal back out to where it was before welding. heating the metal while welding usually causes the weld area to shrink when it cools-more than the surrounding metal does, so the seam ends up actually shorter than the surrounding area. I would try that-be aggresive with the hamme on dolly so the metal can expand
05-10-2023, 06:15 PM | #6 | |
Re: go easy please
Even if I cut the other side open for an access panel ..... could end up having same issue there when I weld it back up
05-10-2023, 06:42 PM | #7 |
Re: go easy please
I agree...needs hammer and dolley..that weld seam needs stretched..
Trying to pull on it will make a bad situation worse
05-11-2023, 03:46 PM | #8 |
Re: go easy please
That is somewhat typical of running too long of a bead at one time and getting the panel too hot.
Right now, hopefully Martin Sr checks in and sees it and offers his ideas on how to go about fixing it. It's not going to be an easy process though.
05-11-2023, 03:55 PM | #9 |
Re: go easy please
Quit trying to metal finish your truck. No way to get in there with the dolly, fill it and see what it looks like. At some point you have to realize that you are not a pro and just go with it.
Or spend the next 10 years cutting out non-perfection.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-11-2023, 04:11 PM | #10 | |
Re: go easy please
Just kind of been a bummer. I worked on the engine and transmission and got that working 2?years back. Then slowly just spent a little bit of time here and there on the metal as mainly been fishing ...... but just cant seem to get the hang of it.
05-11-2023, 04:30 PM | #11 |
Re: go easy please
Filling that would not be a failure just traditional hot rodding, anyone that disses it has either never built a car with their own hands or is a tool.
Do what you are able but finish your truck and drive it. What I see here looks pretty good, nice solid weld, clean panel that just needs the last touches. If you really can't get inside with a dolly, I see two options: fill it up and fix it better next time. slit it along the weld with a thin cutting disk until it pops out. Do 3-4 single spot tack welds spaced along the slit and let it cool totally. Grind the spots flat, let it cool, evaluate. add another 3-4 spots and repeat. Keep going until it starts to pull flat. fill what is left. seal from inside. |
05-11-2023, 05:00 PM | #12 | |
Re: go easy please
05-11-2023, 07:56 PM | #13 |
Re: go easy please
or...when you move, keep your eyes open for donor parts as you travel crosscountry, lots of good steel once you pass thru Ok..might find you a good door that doesnt need major surgery
bottom line is , its hard to do it right when you have no access .. ive got a similar weld ill be making on a upcoming project, where i wont have any access to the backside of the weld, ive been thinking about making a access hole where i can get my hands in there to it, then making a cover to go over the hole, held with screws, not weld you might could do something similar in the lower portion of the door, cut a access hole, then make a cover for the hole, or mount a speaker in it ..something along those lines..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-13-2023 at 12:10 AM. |
05-12-2023, 10:22 AM | #14 |
Re: go easy please
thx all
packing up to move the entire house from FL to west of seatlle in 2 weeks Hope to buy a house with a 2+ car garage sometime in next 6 months - and give her more attention when IM not fishing.
05-12-2023, 08:40 PM | #15 |
Re: go easy please
well, i quit going to fl cuz it got expensive to winter there. 5 years ago, fakky and i were supposed to meet up at his place, until i messed up my back putting a roof on a shed. now i winter padre island tx, but my son lives in west seattle. we may meet up eventually, i'm headed out there next week. where abouts are you looking? be prepared for sticker shock...
05-13-2023, 08:28 AM | #16 | |
Re: go easy please
Wife and sister went out there to scope it out as we are moving there simply as its one area of the country we haven't lived. We love mountains and hiking and fishing though so that also added in. Sequim,WA backing onto the olympic peninsula is the goal. Yes everything has gotten crazy on pricing - I forgot to grab my coffee going down to pick up a welding gas tank refill - decided I needed one ...... a 50c coffee and a 50c bacon biscuit ... $9 ....... about dropped it and ran. Houses seem ok - high - but they are high here in FL too. Might rent for a few months but got to live somewhere Yes anytime drop by !
05-13-2023, 11:17 AM | #17 |
Re: go easy please
I have a nephew in Humptulips. Sequim is the closest civilization to him
05-13-2023, 12:38 PM | #18 | |
Re: go easy please
Worried a bit about the rain - but figure if I have a big shed - good days for truck work And rain never stopped me fishing only lightening
05-13-2023, 12:40 PM | #19 |
Re: go easy please
When I transport the vehicle ...... there are large gaps in doors/windows due to
1) Old car 2) Most doors/windows dont have the factor seal in place now whilst working on them 3) Gaps from adjusting lower skins and so on Was thinking about putting some carpet protector/wrap around the widows for transport .... but not sure how well will hold 10 days on road. Thoughts of caulking with a cheap silicon caulk all the windows and doors apart from drivers side door ? Cant see why not ?
05-15-2023, 12:15 PM | #20 |
Re: go easy please
my bad, i'm thinking of Hoquiam down south, BUT i have another nephew in port townsend and friends in port ludlow. it's definitely rainy there but i don't see much difference from florida, other than the occasional snow and cool weather. i believe mr48 lives up on the peninsula
