05-17-2023, 05:37 PM | #1 |
425hp409
Driveshaft question
I am converting my 68 short bed from small block, TH700R4 and 2 piece driveshaft to a 396, TH700 R4. Since I have to move the transmission back 1.5" to accommodate the engine, can I use a one piece driveshaft that will be 58" long?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
05-17-2023, 10:16 PM | #2 |
Re: Driveshaft question
I always rely on my some what local drive shaft shop for their direction. Length, diameter and max engine rpm all factor into the design of the drive shaft. I would upgrade to 1350 u-joints.
05-17-2023, 11:03 PM | #3 |
I went from a long bed to a short bed and I'm running a driveshaft a little longer than 58", based on several other builds I studied. I'm not on the road yet so take that for what it's worth.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
05-17-2023, 11:53 PM | #4 |
I have a swb 396/700r4 with a single piece ds. I want to say it was 58.5” but that’s just from memory.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Thank you all so far you are angels!! Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
05-18-2023, 10:36 AM | #5 |
Part of what determines the limits of drive line length is the intended usage along with gear ratio, tire diameter, transmission top gear ratio, engine horsepower. These factors determine the maximum RPM of the driveline as well as how much torque it will be required to absorb.
There is a maximum RPM that a drive line can turn at before it starts it reaches critical speed. The length, diameter, and material used in the driveline determine its critical speed. The critical speed is basically the RPM at which the drive line starts to whip or bend so it resembles a jump rope which can be felt as a vibration in the vehicle. Exceeding the critical speed will lead to driveline failure due to fatiguing of the driveline material. The longer time and/or the greater amount of RPM you exceed the critical speed causes the failure to happen sooner. Spicer has calculator to help determine what the critical speed of your driveline would be. https://spicerparts.com/calculators/...rpm-calculator Then you need to calculate what the maximum RPM your driveline would turn at to see if you're in danger of exceeding the critical speed. https://www.dennysdriveshaft.com/pot...alculator.html
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
