It'd be alot cooler if you did
Moving front wheels forwards
I'm putting a new crossmember in the 70 that I am working on and I want to center the wheels in the wheel well. How much should I move it forward? It looks like it need about 1.25" to center it up. Any ideas?
belly dragger
What about the steering box?
Back from the Dead
Member Slammed67 did the mod I think you are refering to on his truck. Checkout this post; http://67-72chevytrucks.com/vboard/s...ight=slammed67
Hope that helps, Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
#4 | |
belly dragger
DAMN i WAS HOPING FOR SOME NEW INSIGHT
Progress = 0%
I moved mine 1.5" forward and it's pretty close to being centered. However with a whole new front clip, it may be a different story.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#7 | |
Project56 on hold
plumb bob the centerline of where you want the centerline of your front wheels. that will be the centerline of your mustang II crossmember. you will most likely need new motor mount provisions. good luck!
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold |
Progress = 0%
Yeah, I'd drop a line (with the truck sitting level front-to-back) just to make sure. I just kind of eye-balled mine and 1.5" seemed to work. I'd say you'll be looking at 1.25 to 1.5". The dimension will also depend on your ride height (assuming you are trying to center the wheel at ride height).
