01-08-2004, 10:35 AM | #1 |
Popping exhaust??
I've been really busy at work and home lately so haven't been around the site in awhile.
I have a quick question. My '86 burb has single exhaust with a glass pack. I know glass packs are supposed to be kinda poppy, but mine is doing weird stuff. When I'm at the upper point of my shift points (rpms are up) and quickly let off the gas, my exhaust has been popping really bad. Sometimes, it almost sounds like a gun shot. It hasn't always done this, just the past several months. Could it be a timing issue or is it just a warn out glass pack?
Scott Shelbourne |
01-08-2004, 11:46 AM | #2 |
Professional Grade
Mine does this too with my single muffler, it seems to be a carb related problem for me.... When I get my timing, valves and idle perfect all those sorta things disspear, unfortunately, my truck seems to have an issue with holding the valve lash properly and it slowly degrades...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-08-2004, 12:00 PM | #3 |
After I fixed an exhaust leak, mine stopped popping like that.
01-08-2004, 12:01 PM | #4 |
I could definitely use a carb tuning so you're right, that might also have something to do with it.
I don't have any exhaust leaks, so I can rule that out.
Scott Shelbourne |
01-08-2004, 12:18 PM | #5 |
Professional Grade
Yep, after I go through and time her up and reset the valve lash, I'm always so amazed by how well she runs, then within 100 km or so my number 5 exhaust valve starts ticking again, next time I'm gonna use some of the red thread lockings stuff, see if that will stand up to the oil and hold the lash properly...
My carb has never been tuned before, and probally needs a new fuel filter too, timing seems to be about correct...
01-08-2004, 12:21 PM | #6 |
Robert Olson Transport
i had one like that and we had to retard the timing a bit, but as for an exhaust leak i dont know it sounds possible. another time on an older truck it was the condensor
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-08-2004, 02:50 PM | #7 | |
Scott Shelbourne |
01-08-2004, 04:58 PM | #8 |
Stylin
my 305 did that with dual exhaust and glass packs. i never found out what caused it so i had fun with it a couple of times id sit at the stop light or around town and make it pop constantly did it around 4k, my exhaust sounded like a semiautomatic gun or popcorn popping lol
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
01-08-2004, 05:00 PM | #9 | |
Scott Shelbourne |
01-08-2004, 05:24 PM | #10 |
driving is in my blood
Put the vaccum advance on manifold and not ported. On ported vaccum setups, you let off the throttle and the vaccum closes and pulls timing, so the air/fuel ignites too late in the exaust. My truck will do this if I have the timing backed off too much.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-08-2004, 05:26 PM | #11 | |
Scott Shelbourne |
01-08-2004, 05:35 PM | #12 |
Stylin
i had mine hooked up diffrently twice i had it off the manifold and then i had it off the full vaccum port off the carb. niether one made a difference. didnt have an smog pump(air pump) on it either
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ Last edited by crackajacka; 01-08-2004 at 06:09 PM. |
01-08-2004, 06:00 PM | #13 |
From my experience, I was chasing what I thought was a backfire or exhaust leak, and it turned out to be the check valves that go inline with the AIR pump. So if you have one, check these valves, if they aren't working right they allow exhaust to go through them and sound like a backfire through the divertor.
01-08-2004, 10:16 PM | #14 |
Here's another easy one. How old is the glasspack? Its possible that the glass inside has been blown out or packed back into an odd situation causing some funky back pressure scenarios. If its several years old (some can blow out even faster) might as well replace it since they are fairly cheap.
