![]() Join Date: Aug 2014
Anybody running manual disc brakes? Pics
Hi there in order to do some troubleshooting on my 1971 GMC 1/2 ton CORRECTION (71 cab on a 69 chassis) that came with factory drum brakes at all four corners that I have since converted to disc in the front I need to install a non power disk brake master cylinder and I would love to see some pics of how that mounts. My drum/drum setup was power so it had the big vacuum booster can on it
please and thank you Last edited by Gregski; 06-04-2023 at 02:07 PM. |
![]() Join Date: Apr 2016
Re: Anybody running manual disc brakes? Pics
1971 with drum brakes in front, I didn't know there was such a thing.
I have a 1969 C10, I put on it 1971 donor front disc brakes and spindles with new 1971-72 ball joints and steel brake tubing, and 1971 donor rear drum brakes and new 5-lug conversion rear axle shafts. I did manual brakes. The master cylinder bolts directly to the firewall. http://www.67-72chevytrucks.com/vboard//showthread.php?p=9167631#post9167631 Last edited by dmjlambert; 06-04-2023 at 11:30 AM. |
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
1971 was the first year of disc brakes in all the trucks. There were many trucks with manual disc brakes from the factory.
Yes that is what I thought, and I didn't know front drum brakes were an option for 1971. Gregski may have had the only one. Or it may be a GMC thing.
#6 | |
"Drum to Disc" conversions 67-70 pics and videos Last edited by Gregski; 06-04-2023 at 02:07 PM. |
At the body shop.
I do on my squarebody. Master from a '84 with manual brakes.
Aluminum master plastic reservoir
" That didnt make it any newer " " Dont antique the equipment " |
![]() Join Date: Oct 2009
yes, you can bolt directly to the firewall per djmlambert's great pic (pro looking conversion!). Also note he's got 3/16" lines on the disk circuit and 1/4" lines on the drum circuit, just like the factory 71+ disk/drum set-up. A stock 71-72 combo valve would be perfect, or you can run an aftermarket adjustable prop valve - but you are correct in that the original distribution block from a 69 is not the correct valve for your soon-to-be-modified brake system. It appears you have the correct mc in your 1st post; assuming you purchased a manual brake mc (for disk/drum), it should have the deep hole in the rear piston (as opposed to the little shallow hole that accepts the short intermediate push-rod associated with a booster. Recommend check that your mc has a deep hole piston in the bore where it accepts the brake pedal pushrod. If it doesn't, i.e. just has a shallow little depression where the push-rod goes, then you may have a power brake mc (for disk/drum).
I sold my 71 gmc 1500 a few years ago. It came with non power discs up front. Master was mounted to the firewall just like in the photo above. It took me a few attempts to locate the proper NON POWER master, finally got it at Napa by going into the old paper parts books. Guy on counter was useless.
71 C-20 07 Magnum RT AWD |
#10 | |
#11 | |
I will check like you suggested |
#12 | |
Some Specs BrakeBest Select Brake Master Cylinder - New - NMC11339 Warranty: Limited Lifetime Warranty Unit of Measure: Each UPC: # 848074025655 New Or Remanufactured: New Dust Boot Included: No Number Of Ports: 2 Bore Size (in): 1.130 Inch Reservoir Included: Yes Bore Size (mm): 28.58mm Reservoir Type: Integral Number Of Pistons: 1 Sensor Included: No Number Of Mounting Holes: 2 Gasket Or Seal Included: No Bleeder Kit Included: Yes Pedal Rod Included: No Brake Booster Included: No Port 1 Thread Size (Forward) (in): 1/2-20 Inch Port 1 Thread Type (Forward): Inverted Flare Port 2 Thread Size (in): 9/16-18 Inch Port 2 Thread Type: Inverted Flare Master Cylinder Body Material: Cast Iron Last edited by Gregski; 06-04-2023 at 09:07 PM. |
my 72 was manual disc/drum but I converted to power.
Here is a pic as it was with stock manual MC |
Gregski, LMC used to carry manual vs power 71-72 master cylinders - here's a part # ref for you - https://67-72chevytrucks.com/vboard/...81&postcount=7
#15 |
Love your L6 with power steering !
#16 |
If its mine your talking about, yeah it is factory PS. I pulled the huge stock steering wheel and put in a smaller one as at 6'2" My leg was sideways to hit the brakes. Easy turning with the power with smaller wheel
Now power disc/drum brakes to.... |
#17 |
![]() Join Date: Feb 2016
I don't know for sure about the master cylinders for manual disc brakes in our trucks, but I do know that in Pontiacs that the manual disc master cylinders were a one year only option and they had a different bore diameter than the power brake master cylinders did.
Last time searched for one I had to have the counterman look the number up in a BOOK! ![]() I would bet the bore diameters are different for our trucks also.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#18 | |
This is the same thread where 54blackhornet discussed his research at NAPA going into paper parts books to figure out the correct master cylinder. http://67-72chevytrucks.com/vboard/s...30#post8909230 |
#19 |
yep, 2nd the motion that you have a deep hole non-power brake mc - good news!
#20 |
and a few hours and a bucket of sweat later she's on
#21 |
![]() Join Date: Jan 2009
Wait!? You are building an electric truck with manual brakes!?
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#22 |
yes, lol, please watch the video
#23 |
hey bro, hey bro, what kinda carburetor are you running is that one of them organic Holley Carter Rochester Quadrajet Edelbrocks?
#24 |
#25 |
I think they're called Quadrazaps.
