Old 01-08-2004, 12:43 PM   #1
71Rat
ran out of money
71Rat's Avatar
pic's of auto xmember location?
Hello everyone I am in the process of rebuilding my engine and converting my 3 speed into a 700r4. I have already built the 700r4 and i am working on the engine now. The problem I have is I don't know were to put in the auto crossmember. I know i have to take the stick crossmember out and i think i know were the auto one goes, but there are a set of holes aready in my frame. do i use them? if someone has a picture of where there crossmember is located that would be great. Ohh yeah the engine is a 350 and in the stock location, and i will be putting in a 700r4 (but i think that it is the same location as a turbo 350)
thanks for everything
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 01-08-2004, 01:07 PM   #2
Randy70C-10
Randy70C-10's Avatar
Yes, use the holes that are already there. Don't worry about which tranny you have, I'm pretty sure that all the automatics go in the same place.
Randy70C-10 is offline   Reply With Quote
Old 01-08-2004, 01:28 PM   #3
Mixup
My truck was a 4 speed 6cyl originally. Then it was a V8 with a turbo 350. Now it has a 700R and I had to drill new holes for the cross member.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 01-08-2004, 02:38 PM   #4
67chevemall
67chevemall's Avatar
Why would you want Auto over Stick!!
Are you sure your OK?
Good luck!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-08-2004, 02:51 PM   #5
bigvinnie
bigvinnie's Avatar
what I did was slide the xmember into the frame and push it back enough so I could jack the trans up and bolt it to the motor, then supported the trans with a jack so I could slide the xmember in place and loosely attach the rear trans mount so I could take measurements and make marks for where to drill the new holes...
Takes all the guess work out of it....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 01-08-2004, 06:16 PM   #6
71Rat
ran out of money
71Rat's Avatar
What i am trying to do is have the crossmember in so i can bolt the engine and trans together and put them in as a whole. thats why i was looking for pictures, and maybe measurments. but i guess i am going to have to wait untill i have the engine done.
67chevemall-Yes i am fine, my 3 speed had major problems with it, went threw a clutch every 3 months and just didn't like being run hard. I felt as though the auto would give me more consistant times at the track, and with the 3 speed i had to lift the engine to get the clutch past the xmember (pain in the @$$). don't get me wrong i love sticks and my next project is going to be a stick, plus i drive an 89 blazer every day and that is lifted with an sm465. and thank you for the luck... i am going to need it with this truck
Randy70c-10: do you have a pic of the holes to use. i guess the one of the owners before me put some extra holes in, so the crossmember can fit into 2 places, one more forward and one more rear. thanks for the help
sorry to rable on everyone
Old 01-08-2004, 06:25 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
I believe they are all that way. Same frames used for I6's, small blocks, big blocks, PG, TH350 and TH400 trannys. Different drivetrains had different lengths, though they did not vary much, hence multiple hole locations.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-08-2004, 07:13 PM   #8
bigvinnie
bigvinnie's Avatar
yeah I'd wait until I could drop it all in and eyeball it on my own setup vs. using someone else's measurements.... it's a no brainer and you're guaranteed to do it right the first time.
72 Stepside Project
Old 01-08-2004, 08:02 PM   #9
Quagmire
A splendid one to behold
Quagmire's Avatar
i swapped from a 3speed to a 350 auto also. i had to take the stock crossmember out, as you probably know the 3speed is a lot shorter than any auto. anyway, the new crossmember just bolted right up, the holes were already there. when i get home tonight, i will see if i can get a good pic for ya
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 01-08-2004, 08:19 PM   #10
bigvinnie
bigvinnie's Avatar
700 rear trans mount is roughly 1.5 inches further back than a TH350, so the same frame holes won't work...
if I remember correctly, the 2 holes that would be for the rear of the xmember on a th350 application ended up being the 2 front ones for my 700, requiring me to drill new holes for the rear xmember bolts only....
so, for my setup at least, I could use the stock holes for the front of the xmember, and only had to drill for the rear xmember holes.
This was for a smallblock mounted in the stock location on a short stepside truck originally equipped with a 6 cyl and muncie three speed column shift trans...
Hope that made sense....????
72 Stepside Project
Old 01-08-2004, 08:37 PM   #11
Randy70C-10
Good info, that means now I have to go and move mine back.
Old 01-08-2004, 08:46 PM   #12
Quagmire
Quagmire's Avatar
yeah, ok...that makes since
67 swb
02 wrx
Old 01-09-2004, 12:16 PM   #13
71Rat
ran out of money
71Rat's Avatar
thanks everyone for the help, looks like i will just have to grind the old cross member out and then when i put the engine and trans back in line up the auto crossmember and drill/bolt it in there........
thanks again for everyones help
