06-14-2023, 09:45 PM | #1 |
Park lights, but no tail lights??
All of a sudden, both tail lights quit working. Brake lights and front park lights are working fine. I am guessing there is a factory connection somewhere that provides power from the #40 circuit to sends +12 to the front harness for the park lights and to the back harness that runs along the frame rail to the taillights. Can anybody tell me where this splice is ?
06-15-2023, 12:23 AM | #2 |
Re: Park lights, but no tail lights??
Check fuses first, then check light bulbs (even if 2 go out at one time). Then check other things. There is a ribbon cable of 4 wires that goes from the cab firewall above the transmission hump, underneath the truck along the frame to the rear of the truck. See if that is in good shape and use a multimeter or lighted tester probe to check for voltages. Many trucks have mangled wiring at the rear of the truck where the previous owner tried to connect a flat 4 trailer connector, so check out that wiring. Here is a wiring diagram: http://67-72chevytrucks.com/vboard/s...27#post9186727
06-15-2023, 12:40 AM | #3 |
And I believe there is not really a wire splice that joins front park lighting to tail lights. I could be mistaken but I think the front park light and tail light wires get power from individual brown wires that go to the headlight switch connector.
06-15-2023, 12:51 AM | #4 |
Check Grounding Also.
06-15-2023, 06:14 AM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
This! While your checking that ribbon alo0ng the frame for continuity, make sure the bed is grounded to the frame. The frame should be grounded to the motor, and motor to the negative terminal on the battery.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-15-2023, 07:18 AM | #6 |
Don’t think a ground is the problem . If the turn signals and brake lights work it’s grounding a bad ground in my experience will cause the turn indicator to glow as it backfeeds searching for ground . Could be a bad headlamp switch? Or just a pinched or broken wire like said check the bulbs first one may have gone out before the other and wasn’t noticed .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-15-2023, 01:48 PM | #7 |
Do the dash lights work, they are on the same fuse circuit
06-15-2023, 03:27 PM | #8 |
Good advice here. Check fuse first, Then I'd go to the connection at the firewall where it exits the cab. If you have no power there my guess would be headlight switch.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
