Old 06-23-2023, 08:05 PM   #1
PbFut
6 port fuel valve
Has anyone else used this valve?
https://www.amazon.com/Compatible-Se...s%2C242&sr=8-4
I am experiencing erratic behavore with the sender unit internal switch. Unsure if the cheap summit sender is sticking or if the valve is not allowing the voltage to pass through the internal switch reliably. I dasie chained 2 valves allowing for selection of main and 2 saddle tanks. Flow works correctly but I'm getting sporadic or delayed sender connection. Or the sender units are hanging. Not sure which.
PbFut is offline   Reply With Quote
Old 06-26-2023, 10:20 AM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
Re: 6 port fuel valve
https://www.amazon.com/dp/B001ESA8LS...roduct_details
i just installed this one.. did you install filters between the tank and the switch?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 06-26-2023, 08:40 PM   #3
PbFut
I got pretty educated on these valve over last couple months. The 6 port and 3 port valve are identical. 3 port simply has the return 5/16 ports capped. So buy which ever is cheaper and cap or remove caps as needed. There is an internal switch for the guage sensors if needed. I am unsure if the switch is electronic or mechanical. I am experiencing intermittent signal from my guage senders but I suspect it is the sending units not the valve. This valve is sold under many names. All manufactured by same company. Oh and yes, filters in front of the valve on all 3 tanks. You dasie chain 2 valve to be able to select 3 tanks. You use a 3 position 4 pole rotary switch to control all 3 tanks.
