Trailing Arm Question
Trying to decide if I should flip the front trailing arm hangers, is there a great benefit to it?
Senior Moment
![]() Join Date: Mar 2002
Re: Trailing Arm Question
I believe it would change your pinion angle which you don’t want
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Depends it you are lowered or not. Mine are flipped.
![]() Join Date: Feb 2016
Is your truck lowered and if so how much?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Apr 2023
Some good discussion at the here and in the embedded thread linked on post 7
http://67-72chevytrucks.com/vboard/s...d.php?t=439768 |
I plan on lowering it 6" in the rear.
![]() ![]() Join Date: Jan 2011
Yes. If you have access to the brackets (is the bed off now?) It is worth the effort, especially if you're going to replace the TA bushings.
Flipping the brackets will make the truck 'think' its only lowered 2, maybe 3 inches. It also seems to help with lateral geometry and flex. I have personal experience with it and I'd do it again, absolutely. How do you plan on achieving the 6" drop? All spring, or maybe a combination of drop springs, + a lowering block?
4" drop springs, 2" blocks
I think CC69Rat definitely hit the real key point in doing this mod. As for the pinion angle benefit, it could be good or bad depending on your setup. If you only drop a small amount, regaining closer to stock pinion angle is good. On my truck, however, I dropped the rear 11 inches and did the trailing arm bracket flip. I actually had to add pinion shims on my rear to negate the change in pinion angle that the bracket flip gave me. This was because I have a two piece driveshaft and I had to raise the center carrier bearing in order to get my driveshaft angles into spec.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
4in spring, 2 in block
I'd add a 3 deg shim a nice double adjustable track bar, shock relocation brackets, clean it good and detail it and drive it like you stole it. Unless you're going really low (or all spring drop to achieve 6") and/or going to be tracking the truck, auto cross, etc. In my opinion you will be very happy with it without flipping the brackets. Or, if you just want to flip them over, then you can likely get away without the 3 deg shims. Good call on 4in spring, + 2in block. It will ride much better than a 6in spring. I can elaborate if necessary.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) Last edited by CC69Rat; 06-28-2023 at 05:34 PM. |
