Old 06-28-2023, 02:31 PM   #1
Mike66C10
Lightbulb Fleetside bed mat
Hi. I'm looking a bed mat that would fit a 66 C10 fleetside. I have a short bed, but I can cut down anything that would fit.
Has anyone tried a 67-72 mat in a 60-66 fleetside? It's tough to find dimensions of truck beds, not just L x W but where the wheel arches are, or id just compare measurements.
I read posts about mold growing under mats, but this is for temporary use for hauling stuff.
Also, if you don't use a bed mat, what do y'all do to protect the bed wood when you're hauling stuff? Sheet of plywood, cardboard...?
Thanks for reading, and for any ideas.
Mike66C10 is offline   Reply With Quote
Old 06-28-2023, 02:51 PM   #2
Mike66C10
Re: Fleetside bed mat
Can't believe I forgot the obligatory photo.
Old 06-28-2023, 02:56 PM   #3
88Stanger
88Stanger's Avatar
Maybe consider a "horse stall matt"? Cut to form
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 06-28-2023, 03:57 PM   #4
60short
Revitalizing a 6T C10
60short's Avatar
nice looking truck...
as far as temp use - like 88 Stanger said - Tractor Supply had some thick (3/4 in) rubber 6ft x4.5 foot mats for like $20 not too long ago
you might even be able to get some carpet remnants - you could even put the carpet side down to not damage the wood.
or a few refrigerator boxes?
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 06-28-2023, 07:32 PM   #5
61hawk
61hawk's Avatar
Since I couldn't find a custom sized mat I just went with the one from Summit Racing. It fits from the cab to the tailgate and between the wheel wells.
https://www.summitracing.com/parts/sum-5005
61hawk is offline   Reply With Quote
Old 06-28-2023, 07:46 PM   #6
61hawk
61hawk's Avatar
Those are 4' x 6' x 3/4" so you'd need to buy two of them and seam them at the center of the bed. They're also 123 pounds each. Current price is $55 each.
The edges aren't exactly cut clean so you'd have to use a straight edge if you wanted a clean seam... not hard to do with a utility knife and a new blade, it just takes multiple passes.
Old 06-28-2023, 11:17 PM   #7
cwcarpenter98
cwcarpenter98's Avatar
I put 60-66 long bed sides on a 67-72 long bed steel floor. Used the 60-66 wheel tubs. Every bolt lined up perfectly. If you can source a 67-72 mat, I think it'll work for 60-66.
Please let us know what you end up doing. I've been throwing a moving blanket in when hauling other 60-66 parts, but would like to find something more durable for when I want to haul some heavier things. It would be nice to have a mat that's light enough to remove easily when not hauling so the bed wood, arguably the nicest part of my entire truck, can be visible
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-29-2023, 03:53 AM   #8
Mike66C10
Great ideas. Much appreciated. Especially good to know the 67-72 sides bolted up. With that in mind, I may try the Holley 67-72 mat and see how it fits...if the Tractor Supply mats aren't still on sale.
Either way, I'll report back. Thanks
Old 06-30-2023, 02:55 AM   #9
PowerdbyChevy79
PowerdbyChevy79's Avatar
Yea i dont think anyone sells a bed mat for 60-66 trucks.. best bet would be to make a 67-72 mat work.. or another option is look on Facebook marketplace for 4 x 8 gym mats.. people usually sell em for $30-40 dollars and they are thick..just an idea..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
bed mat, bed wood, fleetside
