Old 01-08-2004, 08:35 PM   #1
fast14
fast14's Avatar
engine swap question
What all will have to be done to swap from an inline 6 to a 350??? Are the existing motor mounts the same?? Thanks.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 01-08-2004, 09:08 PM   #2
1972C10
1972C10's Avatar
You will need a set of V8 stands you can look at the six stands the the V8 ones and see the difference Here is a link where i have some pics the V8 stands place the motor alot further foward
http://67-72chevytrucks.com/vboard/s...ht=cleaning+up
1972C10 is offline   Reply With Quote
Old 01-08-2004, 09:12 PM   #3
fast14
fast14's Avatar
I hadn't even thougth of that. I'm posting this question for a kid I know. His v-6 mounts looked similar but I didn't know there was a difference.
Just a little crazy
Old 01-08-2004, 10:13 PM   #4
67dragtruck
67dragtruck's Avatar
mounts
A whole lot of people have put small blocks on the v6 mounts. It sets the motor back and puts the distributor very close to the firewall, especially with an HEI. Depending on what distributor you are running it does work though.
Tom
67dragtruck is offline   Reply With Quote
Old 01-09-2004, 01:39 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is this a V-6, or an inline,? you've indicated both.
If it is a V-6, I think you can use the old towers, I have been told mine are V-6 towers, and I would believe it since that's what my truck had originally.
If it is an inline...I think the 250 towers can be retained....and only the odd ball forward mount on a 292 needs to be swapped.
Nothing wrong with setting the engine in the inline position, esp if hooking up to original 3 or 4 speed manual tranny. Much easier that way, plus no drive shaft mods.
A 4X4 fan shroud will work perfectly up front if small block is in the inline location.
Old 01-09-2004, 06:48 AM   #6
fast14
fast14's Avatar
I'm sorry, it's an inline 6. He is wanting to keep his four speed manual and I had been wondering about the driveshaft deal and stuff also.
Just a little crazy
Old 01-09-2004, 11:07 AM   #7
Longhorn Man
If it is a 250, then just yank it out and stab the small block into the exact same location.
Old 01-09-2004, 11:35 AM   #8
dubie
dubie's Avatar
I just did the swap 4 weeks ago. Here is a pic to show how close an HEI sits to the fire wall
and here is how far back the engine sits
It is a direct drop into place swap if you use the inline 6 stands.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 01-09-2004, 11:53 AM   #9
fast14
fast14's Avatar
That looks like about where the motor sits in my 70 four wheel drive. The fram has three holes right for the motor placement?? My other buddies 72 uses the front two and mine uses the back two. I guess that would be alright though.
Just a little crazy
Old 01-09-2004, 11:59 AM   #10
dubie
dubie's Avatar
all the 4x4's from this era are situated in the rear position or inline 6 position in a 2wd truck. Yeah there are 3 holes for the inline spot and 3 for the V8 spot and are all pre drilled into the frame and cross member
Old 01-09-2004, 12:35 PM   #11
Blue Beard
Blue Beard's Avatar
Don't forget about the old wire from the dist to the starter has to be removed with the HEI......
Keep us posted with pics of transplant....might help other members....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-12-2004, 05:56 PM   #12
fast14
fast14's Avatar
Okay, does anybody know what headers will fit?? It has a 4 speed tranny with the manual z link clutch linkage.
Just a little crazy
Old 01-12-2004, 06:42 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Hooker comps fit my 69 when I put a 350 in the 6 cyl place. All of the clutch linkage fit fine, but you need a clutch pivot ball that screws into the V8 block. It's different than the 6 cyl one.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-12-2004, 06:45 PM   #14
fast14
fast14's Avatar
Do you have a part number handy for those headers??
Just a little crazy
Old 01-12-2004, 06:50 PM   #15
Tx Firefighter
Here you go........
click HERE
