Old 07-03-2023, 07:08 AM   #1
AlaskaK10
Junior Member
292 in 1966 K10 4X4
Hi
I'm looking for the parts needed to mount a 292 in my 1966 K10. I understand it takes a special offset cross member . If anyone has the parts needed let me know
AlaskaK10 is offline   Reply With Quote
Old 07-03-2023, 10:26 AM   #2
60-66
60-66's Avatar
Re: 292 in 1966 K10 4X4
You need the right hand , or passenger side frame mount only . No crossmember
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-03-2023, 11:23 AM   #3
Lokin4AReason
Lokin4AReason's Avatar
Like he said ^ ^ ^ ^ ^
Its the only thing different from the rest of the inline 6s
Motor mount location(s) are different on the passenger side for the 292 than on the 250 and 230 ( which are the same )
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 07-03-2023, 12:16 PM   #4
AlaskaK10
Junior Member
Thanks for the reply
Thats for a 4X4 correct
Old 07-03-2023, 12:42 PM   #5
Short 3/4
Yes, you are correct. The holes for it should already be in the frame. Unfortunately the 292 perch is unique, you can’t just find the ‘everything else’ part and move it forward
Although it’s a fairly rare part, I and others have found it through the help of others on this forum. Good luck in your search
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 07-03-2023, 03:49 PM   #6
AlaskaK10
Junior Member
So what does it look like can you post a picture ?
Old 07-04-2023, 12:25 AM   #7
Short 3/4
Aerotruk63 posted a picture of what you are looking for on a stripped out 4x4 frame in the parts for sale section. Check it out.
292-SM420-T221
Old 07-04-2023, 08:52 AM   #8
AlaskaK10
Junior Member
Smile Re: 292 in 1966 K10 4X4
Thanks for the picture
