Tie Rod/Center Link Question
I had someone change out my ball joints and tie rods. After looking at the tie rods, it looks like they are backwards (Castle nut pointed towards cab). Anyway, can I swap all of this around (Tie rods/Center link) without having to take the front wheels off or do I need to remove the front wheels?
Re: Tie Rod/Center Link Question
was the truck converted to power steering and disc brakes?
1967custom |
![]() Join Date: Mar 2003
A LOT easier with the tires off the truck, but it can be done with them off I'd imagine
![]() Join Date: Jun 2022
I can get at those fine from the front. Mighta had the whole front end jacked at the time, ICR. OEM Tools separator fit in there too
#6 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Apr 2016
So I guess you don't want to have the guy who put the center link on backwards re-do that part of the job? You'll need a front end alignment after working on it. I got this style of separator from Harbor Freight and it sure made separating the joints easier.
Thanks, I'll have to grab one from Harbor Freight tomorrow. As for the guy that installed it wrong, he won't be fixing it.
Thanks for all of the feedback. Im assuming if the tie rods are facing the wrong direction, then the center link needs to be flipped (180) as well?
Yes the center link needs to be flipped. It should be very close to the crossmember. The inner tie rod has a grease port while the outer tie rod may not have one. Depending on how the conversion was done and with what parts, you may have a slightly different setup.
Judging from the way the pitman arm is seated in the center link, while the inner tie rod isn't, I don't believe the center link is upside down.. Rather, it needs to be switched end-for-end..
I haven't had time to mess with it yet, but your thinking it needs to be flipped around where the current hole in the center link for the pitman arm is flipped to the idler arm? Are the holes on the center link the same size on both ends? Thanks
It needs to be flipped from end to end and the tie rods come from the inside with the nuts facing forward
Correct.. Plus the inner tie rods should enter the center link from the back side, nuts to the front.... When all of this is accomplished, have the frontend re-aligned..
