Old 08-05-2023, 09:51 PM   #1
pmpski_1
pmpski_1's Avatar
Airbag options for 71 C20
My stalled project has been sitting in my garage for 15 odd years, so I'm not up on all the latest options for lowering my 71 C20. I'm thinking about getting back into it instead of selling it off, but I think I want to do something kind of off the wall.
I'm thinking about putting a flat bed and an airbag suspension on it. Obviously I could do a C10 suspension swap and go that route, but I'm wondering if there are good lowering/airbag options for the C20. Seems like that may be a bit more straightforward. I don't plan on using it for heavy hauling or anything like that, I'm just working with what I have.
Who are the go to companies for these types of kits nowadays?
pmpski_1 is offline   Reply With Quote
Old 08-06-2023, 09:13 AM   #2
Ziegelsteinfaust
Re: Airbag options for 71 C20
Same as a C10, but there are no bolt on options.
Your going to have to cup or plate your arms, amd use C30 drop spindles. If you plan on running low. Pan cake the crossing for better ground clearance. You can do 1.5" with a tie rod flip, or up to 2.5" with a drop tie rod kit.
I suggest using a HD 4 link since flat beds can get chonky.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-06-2023, 11:29 AM   #3
pmpski_1
pmpski_1's Avatar
I started watching youtube videos last night to educate myself on what I'm really getting into and I think the 4 link thing is above my comfort/skill level.
As much as I'd like to, I don't think the "laying frame" thing is in the cards here. I think that would take too big of a notch in the rear frame for me, so a flatbed would end up looking strange because of the height to clear the notch unless I got into something super custom.
Right now the plan is to build my own flatbed, keep it super simple and more period correct, so it won't be too heavy.
But I still want to do airbags, I'm just not getting my sights set on a street scraper.
Old 08-08-2023, 05:20 PM   #4
SCOTI
SCOTI's Avatar
Just like a pre-73 C10, the C20's can have leafs or truck arms out back. Which set-up do you have?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-08-2023, 10:55 PM   #5
pmpski_1
pmpski_1's Avatar
HD leafs. It's a Custom Camper.
Old 08-09-2023, 10:01 AM   #6
SCOTI
SCOTI's Avatar
You could remove some leafs or source a lighter duty C10 sring pack & utilize an Air Over Leaf set-up for height adjustment. That would be the easiest way w/the current set-up. Beyond that, a HD 4-bar would get things done but be more work.
Front is the basic cup/plate/bag set-up as there's no significant difference between the set-up of a C20 vs a C10 as far as swapping to air-ride.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
