![]() Join Date: Jun 2023
Hei or points??
Folks, I am wondeing how many of you are still running the old points style ignition or if you have converted to HEI? if you converted, what style of HEI have you went to?
Thanks, RonWT |
Re: Hei or points??
After watching the timing bounce all over at idle, I decided to replace my original distributor with a MSD street fire HEI distributor. It runs much better, but that might also be because I replaced a tired 307 with a crate 350 at the same time.
![]() Join Date: Jun 2022
Re: Hei or points??
You're a pretty hardcore "Belt and suspenders" guy ;-)
![]() Join Date: Aug 2013
Re: Hei or points??
HEI that is tight may step up the spark a lot. Especially using quality cap/rotor/wires/ect. Another option is this: https://pertronixbrands.com/ I've ran them & the stock cap tales up less space.
![]() Join Date: Feb 2002
Re: Hei or points??
I found a definite performance improvement when converting to HEI. I've done it on V8s as well as my L6.
I ran PerTronix for about 7 years, but it burned out on me. GM Delco-Remy style HEI is the best, and parts are universally available in the US.
Re: Hei or points??
I converted to a Skip White HEI dizzy years ago. The original dizzy, bad bushings made it wobble. At that time, $'s were tight, wanted something quick and easy.
Getting the truck back on the road this summer, wanted to R&R the cap and rotor. Skip White does not sell parts, but would sell me a new dizzy. Local auto parts guy I trust thinks he may have found an Excel cap & rotor. Parts arrive on Tuesday. Good luck...Don |
![]() Join Date: Jan 2001
Re: Hei or points??
I had a factory HEI for years. I decided to upgrade to a Progression Ignition distributor a few months ago and I couldn't be happier. It connects to your phone via Bluetooth and allows you to custom program timing maps on the fly. It also has a lockout function that will keep your vehicle from starting if you lock it on the app.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Hei or points??
Member of the "Points Forever" club here. Both my old dogs still run em. I just can't part with the old Penske.
#9 | |
![]() Join Date: Dec 2009
Re: Hei or points??
Re: Hei or points??
Re: Hei or points??
Re: Hei or points??
I’ll chime in on this.
I wanted a HEI distributor, but wanted to keep the factory look. I switched out my Dual Points for a Mallory Electronic Conversion kit. It worked well for many years, but the module did go bad once, so I put in a new one and haven’t had any issues. |
Re: Hei or points??
I run a HEI I got a new distributor from Summit. It was affordable came with a new cap & rotor. They even sell the wiring pigtail plug for a few bucks so you can make it a plug & play distribuotr.
https://www.summitracing.com/parts/s...ckup/year/1969 https://www.summitracing.com/parts/sum-890148/overview
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
Re: Hei or points??
How about this question? How many of you running points have ever had them suddenly drop dead? How many have had a hei drop dead?
#15 |
Re: Hei or points??
My '69 C 10 also has O.E. distributor . Seems to run fine . Thanks
#16 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Hei or points??
I converted to a used late-Seventies GM HEI back in the early 1980s and couldn't be happier with it.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#17 |
![]() ![]() Join Date: Jul 2002
Re: Hei or points??
That's what i have on my 70. I think only issue in last 25 years was 2 module died. Super dependable.
#18 |
![]() Join Date: Oct 2005
Re: Hei or points??
I have kept the points & cond. because I want to keep everything original on my low mileage 72 Super. I have a GM HEI unit that I have o-hauled that I could put on it but it runs & starts perfectly.
George |
#19 |
Re: Hei or points??
Still running points. When the original dizzy wears out, I'll think about HEI
#20 |
![]() Join Date: Apr 2016
Re: Hei or points??
I have a used 1976 to 1980 GM HEI in mine and I like it.
#21 |
Re: Hei or points??
Not being able to find an original GM HEI I bought a clone off eBay from a firm named BraveX. Billet aluminum housing and good quality oil impregnated drive gear. Cap looks good too. BUT everything electrical is very low quality. The first one lasted about a year before the module died. BraveX replaced it with no questions. Second one lasted about two months. BraveX again replaced it. Third one is in and running great. Let’s see how it goes ? Another problem I have determined is you can’t buy anything under the cap that’s made in the USA any longer.
71 C-20 07 Magnum RT AWD |
#22 |
Re: Hei or points??
Two with factory GM HEI and two still with points they all run well
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#23 | |
Re: Hei or points??
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#24 |
Re: Hei or points??
I added HEI 25 years ago and haven't touched the distributor since.
#25 |
![]() Join Date: Feb 2009
Re: Hei or points??
X2...............I installed a Delco HEI, pulled it out of a 1975ish.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
