Old 08-08-2023, 12:44 PM   #1
OUbesto
OUbesto's Avatar
Correct brake fluid
Hey group, I have a '70, c-10. PO said he replaced front drum brakes with discs from a '71. Original drum brakes are still on the rear wheels. I want to replace the brake fluid since its been in the system for past 9 years. which brake fluid do I use? It seems DOT3 might be the way to go, but.....I just want to get the "experts" and your opinions.
Thanks.
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 08-08-2023, 01:00 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Correct brake fluid
DOT3, assuming he didn't replace the entire brake system and used DOT5.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-08-2023, 01:16 PM   #3
OUbesto
OUbesto's Avatar
Thanks Tony. Unfortunately PO passed away so I cannot ask him. Is there a way for me to "test" to determine if he used DOT3 or 5?
Old 08-08-2023, 01:55 PM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
As long as you flush out the old stuff thoroughly, it won't matter.
BUT, if you really wanted to know, you COULD suck some out into a jar and add water.
If it's 3 or 4, it'll mix, while 5 will stay separate. https://www.youtube.com/watch?v=7gSchzhcslc
Rust_never_sleeps is online now   Reply With Quote
Old 08-08-2023, 02:22 PM   #5
OUbesto
OUbesto's Avatar
Good stuff! Thanks
Old 08-09-2023, 02:17 AM   #6
71CHEVYSHORTBED402
Good chance you know better than I do, but from what I've heard there's no mixing DOT3 and equivalents with DOT5, because that can lead to brake failure, simply because they don't mix, they separate, bubbles and such.
Seems to me you can't flush a system because some of the former will be left in the system, or in other terms, everything that has brake fluid running through it has to be replaced.
For what worth, I saw a video with an engineer demonstrating why DOT5 should not be used in old parts, even if they're rebuilt and clean. That said, others swear by DOT5, so who knows.
Tony
Old 08-08-2023, 01:51 PM   #7
MySons68C20
MySons68C20's Avatar
https://blog.amsoil.com/dot-3-and-do...he-difference/
MySons68C20 is offline   Reply With Quote
Old 08-09-2023, 09:11 AM   #8
dmjlambert
dmjlambert's Avatar
I don't believe it would cause a serious problem if a couple of teaspoons of DOT5 somehow managed to get left in the system after pushing a quart or so of DOT3 through the bleeders. But I also think it is likely there would be no DOT5 remaining. When I change out the fluid in my brakes because I want all fresh and all the same brand and type, I feel pretty confident all of it has been changed. My method is to empty the master cylinder with a spoon and rags and pour the new fluid in there, and open the bleeders at the wheels one at a time, and slowly and steadily press the brake pedal numerous times. I periodically top off the master cylinder with new fluid. I attach a clear hose to the bleeder and extend the hose into a small amount of brake fluid in a can or jar. After several brake pedal presses, all the air will be out of the hose and no new air can get into the hose. After I have about 1 cup of fluid in the jar, the new fluid coming out of the bleeder looks nice and clean and the same color as what I pour into the master cylinder. All the fluid has been changed. If you want extra confidence or extra clean flush out, repeat the process on all 4 wheels and push another quart through there and into the jar. It's a one-person job, no helper is needed.
Old 08-09-2023, 05:52 PM   #9
DOT 5.1 is compatible to DOT 3 and will not cause issues if mixed. DOT 5.0 is the odd ball one as far as brake fluid is concerned. It is good, but you do need to have the old system cleaned/Flushed out to not have the chance of issues.
Old 08-09-2023, 06:30 PM   #10
dmjlambert
dmjlambert's Avatar
DOT5 is purple fluid. On my truck, when I flushed it for the first time in a long time, the fluid that was coming out of the bleeders was purple, but I was the one who originally filled it and I remember using DOT3. I think maybe the DOT3 I used had a color change due to water absorption because the fluid was formulated to change colors to indicate water saturation and time to change. I'm not sure though. The fluid in the master cylinder was honey colored and a little dirty.
Old 08-10-2023, 11:29 AM   #11
MikeB
MikeB's Avatar
Lots of discussions on brake fluid by the geeks (like we aren't?) on the BobIsTheOilGuy.com forum. Dot 3 is the way to go for our trucks. And it seems there is little to no difference among brands. I just bought 2 quarts at a NAPA store for $8.99 each.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
