Old 01-09-2004, 11:20 AM   #1
Primered_69
Primered_69's Avatar
Any kits for BB Cadilac Install in a 69 truck with 350
I have looked at Longhornman's site andit is good but I am more of a bolt on man and would like to know if there is a kit.
I have located an engine for 300 and I am considering this swap.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 01-09-2004, 11:51 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Here you go. An online catalog for caddy info and parts.
http://500cid.com/mts/cat/index.htm
Old 01-09-2004, 12:39 PM   #3
tom hand
CCRider
tom hand's Avatar
http://www.welding-advisers.com/Cutting-torch.html
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 01-09-2004, 01:09 PM   #4
72LS1
This is an easy swap, as far as swaps go.
Not quite bolt in, but not difficult as far as engine swaps go.
I swapped a 500 caddy into a 78 malibu wagon a few years back.
Only took about two weekends to do that - and that's a much tighter fit.
A better source for info on the swap is found at the web site
www.500cid.com
There is a message board there dedicated to caddy motor swaps into all kinds of vehicles.
MTS is the company that runs the board - They can sell you plates that bolt to the caddy motor mounts, but you still have to drill the plates to match your crossmember, and then weld the plates together.
I used used some 1/2 inch plate, and drilled it to fit.
Have fun, those suckers are truly torque pigs!
If you're looking for more fun yet, take a 76 block and bolt on 1970 heads. The chamber CCs go from 120 to 76, compression jumps from 8.5 to 12.
I run 108 octane in it, but man does it move!
Have Fun!!!
72LS1 is offline   Reply With Quote
Old 01-09-2004, 07:14 PM   #5
Longhorn Man
That's a great way to blow up a piston or 8.
Old 01-10-2004, 05:11 PM   #6
72LS1
You know, you should be right, but those caddy long blocks are amazingly stought (and cheap).
I have a couple of caddy 500 blocks sitting in my barn, so I really didn't care if it grenaded itself, but two years later its still running strong!
Old 01-10-2004, 08:06 PM   #7
dinnut
dinnut's Avatar
you could sell those 500 blocks on the parts board!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
