Old 08-10-2023, 07:59 AM   #1
SWB
Active Member
SWB's Avatar
Need assistance identifying 4x4 parts
Hello all, I'm not new to 67-72 pickups, but am new to 4x4's. I recently purchased a 69 4x4 swb and need help Identifying front/rear differential's, Transmission (4-speed w/granny low), and transfer case. Mainly for the purpose of what fluids to put in them. Do I need lsd in the front/rearends. What is the best brand and weight for the transfer case and tranny.
As you can tell I have some cleaning to do, but I am excited.
Pic's attached and once I start de-greasing, I can get better pic's of whatever you need.
Thx
*K10 SWB. Orange/White
*69 Ford F100 21K Actual Miles, 2nd owner in family since new
*67 Chevy II RestoMod, Wilwood all around,
Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc..
SWB is offline   Reply With Quote
Old 08-10-2023, 11:03 AM   #2
kwmech
Re: Need assistance identifying 4x4 parts
Later model chevy 10 bolt front axle---probably converted to disc brake
rear axle is the stock 12 bolt.
trans could be either a SM 420 or 465. 465 will have a pto cover on both sides.
T-case is a rockwell 221
Old 08-10-2023, 04:17 PM   #3
SWB
Active Member
SWB's Avatar
kwmech;9228718]Later model chevy 10 bolt front axle---probably converted to disc brake
T-case is a rockwell 221[/QUOTE]
****Thanks for the info kwmech. Yes, it does have front disc. Once I degrease, I'm sure I'll find more markings/info.****
Old 08-12-2023, 12:34 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Looks like a 465/T225 to me, which it should be for ‘69 as long as nothing has been changed in that dept. A lot can happen in 50+ years.
As for fluids, 80w90 dinosaur gear oil in everything. I use the Napa brand because I get discount from work. Whatever brand you choose will likely be great, they really aren’t that picky. I don’t recommend synthetic though. You won’t need Posi additives unless you’ve got a posi. When you pull the covers (highly unlikely the front has one from the factory) you’ll be able to tell what you’ve got. The rear axle has a decent chance of being original to the truck I would say.
Tyler
57taskforce is online now   Reply With Quote
Old 08-12-2023, 01:09 PM   #5
kwmech
Your steering shock is upside down at the diff by the way
Old 08-12-2023, 01:48 PM   #6
SWB
Active Member
SWB's Avatar
Thanks for the info. Here are a couple more pics
The Tranny has this same plate on both sides and a number on the bottom.
And a direct rear shot or the transfer case
Old 08-14-2023, 03:49 PM   #7
SWB
Active Member
SWB's Avatar
Thanks, I flipped it over. Makes more sense now.
