Old 09-05-2023, 05:13 PM   #1
cdub2010
2001 2500hd 4x4 grinds while in 2wd high
A new to me 2001 2500hd with a manual shift 261hd I assume. Drives fine in 4hi and 4 lo, but when case is in 2 hi it grinds. The transfer case shifts fine it doesnt grind while shifting just whne the truck is moving forward. I have only shifted while stopped with the clutch engaged, not on the fly. Im wondering does this sound like a transfer case problem or an axle acuator problem? Never had problems with any thing newer than an 87 4x4.
cdub2010 is offline   Reply With Quote
Old 09-06-2023, 10:14 AM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 2001 2500hd 4x4 grinds while in 2wd high
My father in law had an 01 2500HD with the 8.1 and 263HD (electric shift version of the 261) case. His did what you are describing and I had to do a full rebuild on the case unfortunately. I’d change the fluid and check it real close for metal.
Tyler
Old 09-06-2023, 03:49 PM   #3
Second Series
Second Series's Avatar
Does the axle actuator disengage in 2wd? I may have had a similar issue with my '90 k1500. The 4wd didn't work one day, after ohming out some wires I replaced the actuator switch in the t-case. I was getting some binding in 2wd, not grinding. The new switch was bad, replaced it again and all was well. I took an ohm-meter to the parts store and tested the new switch there.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
