Old 09-06-2023, 11:05 AM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Truck slows too much when coasting.
1972 C10 350 with turbo 400 trans.
When I let up off the gas, it's like I'm braking. Trans shifts fine. Brakes aren't dragging. Maybe bad torque converter? Thanks.
desert-rat is offline   Reply With Quote
Old 09-07-2023, 11:29 AM   #2
1967GMCC20
1967GMCC20's Avatar
Re: Truck slows too much when coasting.
I had that same problem years ago 78 454 TH400, with stock converter.
Mine was the idle speed was too low. Friend adj. It, he was into trans linkage adj, vacuum and idle speed adj. It had 6 bolt converter.
1967GMCC20 is offline   Reply With Quote
