Question about painting
Im in the process of moving. My truck currently doesn't have the front or back windshield in so I would like to get both windows put in since my truck will be moved and may be exposed to the weather for a while. The truck isn't at the point where I can spray it, still needs body work..etc, and I also don't have the air compressor/spray gun setup that I will need.
I have the paint (3 different colors for the roof, interior and body). I can get the pinch weld areas around the windows cleaned up and ready for paint. My question is, would a foam brush give me a decent finish around the pinch welds and a little beyond the pinch weld area? |
#2 | |
![]() Join Date: Nov 2018
Re: Question about painting
When I was 10 years old I helped my Grandfather paint his 48 Dodge Pickup out on the dairy, blue with black fenders... with brushes. He passed away in 1970 and that truck still looked like it was painted with a broom. |
Is it in Epoxy prime ? If not the whole truck will start to rust exposed to the elements . If it is I would just pop the glass back in as is and then remove when you’re ready to paint .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
I just finished painitng my truck and I would NOT just paint it with a foam brush... You need to put the glass in. Then when you are ready do it right. I promise you will be much happier.
Also if it is unpainted metal it is all gonna rust quickly left to the elements. |
Pretty good chance you will crack the wind shield if you try to remove it for paint.
I would visit your local applinince store and get some heavy duty card board to close up the front a back windows. Same with the side windows. Lots of of duct tape to hold it in place. |
#6 | |
![]() Join Date: Oct 2020
I took my 70 MGB with me to Guam back in 1991 to give me something to do while I was there. It was all in primer (not epoxy). Knowing that the regular sandable primer is porous, I, being the poor airman at the time, sprayed the entire car with clear rattle-can spray paint. It did a great job keeping the car from rusting, but I did have to reapply some clear here and there. I was finally able to get the car painted in a paint booth on base before I shipped the car back. Did I mention the car was on a ship to/from Guam for about 35 days?
If I did any body work, I would always topcoat with clear. I also used a car cover to keep rain/salt spray off to keep things from getting out of hand. Good luck on your project! |
![]() Join Date: Dec 1999
Using cardboard to seal off is a good idea. Using duct tape to put in place is a bad idea. the residue left over is not good for paint to adhere to. Something like blue painters tape is a better option. Another way to go is get a can of 2k paint mixed up for about $30, mask off and paint. There will be some feathering to do, but it will probably be fine. I am referencing single stage paint here which I used on my truck. I am tired off the expensive clear coats failing after just a few years of common use.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
