![]() ![]() Join Date: Feb 2009
WTB, a couple real nice OEM front bumper bolts
Like the ones on the left. Nice shape please, like the ones on the left
![]() Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: May 2021
Re: WTB, a couple real nice OEM front bumper bolts
What do the 'E's look like.
I took picture of this at a 2nd hand store cause I couldnt see that well. Recall seeing 3 bolts. I sold ones off my 69..but they all had a nice discernible 'A' on them.
1970 Barracuda slant 6..the one car I wish I never sold! and long ago 1969 C30 CC soon to be 4x4 1980 Boston Whaler Supercat 17sold, 19sold, 20 |
The "E" bolts are on the left and stamped under the head. The "C" on the right are stamped at the bolt's end like where yours shows an "A".
Include a pic of the letter on bottom of bolt your looking for...it might help. The 'A"s are ones I sold on WTB.
I can't discern the letter stamp on ones I saw at 2nd store weeks ago. Previous pic. Good luck on search.
Picture of the bolts I'm looking for. OEM doesn't necessarily have to be stamped "E". The heads look like the set of four in the OP. Thank you
![]() Join Date: Jan 2004
Tony, Do you have a picture of bumper where the inner bolts fit
& is it recessed ? |
Here's one. Note I found all six bolts pictured in the OP on this truck. Figured the two on the right were installed into the outer holes. I'm not sure they're factory correct. Or if installed by the factory, perhaps they're wrong. I know the four on the left are correct.
Do you notice how the inner 4 are recessed ? The outer are not ? I wonder if the outer two were shorter headed because then the depth of the bolt head would all be the same when fastened/tightened ???
#9 | |
![]() On topic, I have this image of all my bumper bolts. The tops of the front bolts ("E" and "C") look pretty darn close, you might be on to something.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-03-2023 at 01:26 AM. |
For comparison. OEM bumper with bolts shown in the OP.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-03-2023 at 04:04 PM. |
