Exhaust manifold angle?
Gathering parts and pieces to very soon drop in a 8 to replace the 6 in my 66 c10 and manifolds are on my mind currently. My question to you fine folks is which type is best suited for these trucks? Outlet straight down or angled? Downpipes come in either version but to get around clutch linkage or any other clearance issues is my concern. Shift linkage isn't a a concern since this is a sm420 floor shift and will stay floor shift with a new a tremec TKX when the motor goes in.
![]() ![]() ![]() Join Date: Jan 2018
Re: Exhaust manifold angle?
As long as you're keeping the engine in the correct, v8 location for 60-66 trucks, you'll want to use the straight down manifolds. The angled ones were used on the 67-72 trucks that had the v8 sitting further forward in the truck than where the 60-66 v8s sit.
What six do you have? If you have a 230 or 250, you don't have to change the frame side of the engine mounts. If you have a 292, you'll need to change the passenger side, but the driver's side is the same.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#3 | |
Those block huggers look like they'll fit somewhat similar to the factory straight down manifolds
Yea that was my thoughts as well. They have that old school look I wanted with the manifolds but much better flow. Found a new set of stainless on marketplace for $125. I just need the guy to respond now
![]() Join Date: Feb 2010
Option: 2.5" Corvette ramhorns They also come in a straight down configuration, I used them on my V8 with TH400
P.S. They can be found in the 283/327 truck version with drivers side alternator mounting as original |
