10-11-2023, 04:30 PM | #1 |
Junior Member
Original hood hinge colour
Looked through as many posts as I can find but cant seem to find an answer.
What was the original finish on the hood hinges, were they painted? 1970 C10, any help appreciated guys |
10-11-2023, 04:50 PM | #2 |
Re: Original hood hinge colour
I don't believe they were painted. They were dipped in a solution that turned them gray. I thought the chemical was similar to what GM used to blackened bolts.
Paint would get in the way of the function of the hinges. Same finish as the hood locking mechanism. The hood opens and closes so smooth it's amazing. Bead blasted first and then dipped. Will be interested in other comments. Last edited by Accelo; 10-11-2023 at 06:21 PM. |
10-11-2023, 05:01 PM | #3 |
68 C10 Longbed
FWIW I’ve Parkerized them in the past and they turn out a nice grey color and hold up. After a while spray some Boshield on them once in a while and they hold up nicely.
10-11-2023, 05:03 PM | #4 |
Junior Member
Coating in zinc oxide or phosphate possibly? That would turn them grey and protect them
I figured that whatever they were coated in would rub off due to the friction when in use. As you say will be interesting to see others input Last edited by Belsh; 10-11-2023 at 05:07 PM. Reason: Additional info |
10-11-2023, 05:02 PM | #5 |
I believe Accelo's right. They were given a process treatment like phosphating, or Parkerizing. Kind of a gritty-surfaced Cast Iron Grey.
I bought some GM replacement Hood Hinges in the Early Aughts [~2002] from the Chevy dealer. They were a little darker than my originals, but those may have faded with time. Now installed on my '68 C/10 Stepside, and I don't have to slam the hood anymore.
10-11-2023, 05:57 PM | #6 |
Accelo & '68OrangeSunshine's descriptions are accurate. I have several NOS sets with a pair I installed about 12 years ago. That pair looks the same as the ones in waiting. Darkish grey, almost flat blackish.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-11-2023, 06:25 PM | #7 |
I must compliment you guys on your attention to detail ! Learn something from your comments every day…
71 C-20 07 Magnum RT AWD |
10-12-2023, 02:28 PM | #8 |
Do a search on Team Camaro, (camaros.net/forums). Lots of info on hinge and hood latch finishing.
10-12-2023, 04:30 PM | #9 |
I used this product a while ago. Holds up well on the latch. Did not do the hinges. I doubt the color is perfect, but gives a nice contrast to the satin black used elsewhere. If you are simply looking for a contrast as I was, it worked well. 6 months ago everything was looking pretty nice till I ran the truck into the workbench. Banged things up some. Oh well. it's a truck.
10-12-2023, 06:30 PM | #10 |
70+ ( Old Skool Club )
When I bought my truck the back of the hood wouldnt go completely down, so sent them off to this guy Willey and they came back like this. Been on since 2016 and no problems. https://www.hoodhingerepair.com
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-13-2023, 02:40 AM | #11 |
Junior Member
I’ve seen a few mentions of Wiley and seems to always get great feedback. Unfortunately being in England the cost of postage plus the work would come out towards the thick end of $1000. I’m going to have a go at servicing them myself, haven’t decided how I’ll finish them yet but will let you know how I get on. Once again thankyou all for your excellent input.
10-13-2023, 04:30 PM | #12 | |
10-13-2023, 07:25 PM | #13 |
I checked my invoice frpm Willey. Total price in January 2016 was 175.00 without shipping and yes it says used Zinc Phospate Paint, shows 25.00 extra, on them. He also recommended Sea Foam Deep Creep for lubing them.
10-13-2023, 08:43 PM | #14 |
Much appreciated.
