Old 10-20-2023, 08:25 PM   #1
blap
fleetside box gas location
will a 1979 box work on a 1977 frame as far as the gas tube can they be changed to mount up to the door type?
blap is offline   Reply With Quote
Old 10-20-2023, 09:26 PM   #2
Getter-Done
Getter-Done's Avatar
Re: fleetside box gas location
I used an 84 bed on a 78 frame.
Fleet side long bed and actually was set up with dual tanks.
A 77 frame with a 79 box should not cause a lot of issues.
I have swapped a lot of beds and tanks.
From what I remember
The 73- 74ish had a small filler neck throat that attached direct to the bed.
And 75-77 had a bigger filler neck.
Then the 1978 box changed to the door.
The plastic box that mounts the filler neck is part of the swap.
The main thing I remember is the different diameter of the inlet on the tank.
The Early model was smaller/
Then the later model was the middle size.
The tanks with the 6.2 diesel had a bigger inlet.
So it is a matter of What tank / What filler neck / and what Bed.
84 Chevy K-20
