Painter recommendation N CA
Can anyone recommend a painter in the Grass Valley area of Northern CA?
Re: Painter recommendation N CA
Sorry I can't help you. I too am looking for a painter in the Modesto area. Everybody wants to make a quick buck on insurance work. Let me know if you find a fish and I'll do the same for you.
![]() Join Date: Jun 2023
Looking as well in the Redding area
![]() Join Date: Dec 1999
It will be difficult to find a shop that will do a complete repaint in the Ca. Much less, work on a classic. My friend still does but he will retire in the near future (work for him). While he was out with a broken hip I visited at least 15 shops nearby for quote on my 94 complete after a rearend I experienced. Only two got back to me at 12-15k. Minor damage I fixed myself and I supplied the parts. Truck was almost a scuff and shoot.
Found one place that did it for just under 8k with me doing the disassembly and most of the re-install. Clear is already coming off less than 5 years later. We did my 72 with single stage paint I obtained from another state. Was expensive but I have more confidence that the paint will last. Paint and body in Ca is expensive and the products kind of suck. The paint and materials costs are exaggerated and cost of business is high. Hope you find someone that can help you out.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
![]() Join Date: Feb 2009
Perhaps Northern Nevada, I wonder if he's got his business going yet? I've been meaning to ask.
The guy is so MATICULOUS, and because of that, he says he'll never straighten a truck bed's inside again.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() ![]() Join Date: Jan 2005
I used this place in Newcastle, CA about two years ago to repair and repaint several panels on my truck. Despite the name, they work mostly on classics.
https://smithcraftcollision.com/ |
![]() Join Date: Mar 2003
My go to is in Colfax at Hickeys auto body. Jim does really good work
Big bucks?
It's all BIG $$$ now days, A gallon of red base coat is $1000.00 now
A gallon of good body filler is almost $100,00 Sadly that's just the tip of the iceberg |
So I don't know if it would work for you but a local body shop "let" me do all the block sanding both filler and primer prior to final paint. I was under their supervision. The owners words were after I sanded something was "keep sanding".
They sprayed the sealer and base coat clear coat. I did the color sanding staying away from the edges. The body shop finished the edges. And then they did the cut and polish. Started out with this and ended up with this. See pics. Body shops make their money from insurance work. Can't blame them. |
I know a special guy who is opening a shop in Carson City Nv. He has the best qualities, skills and work ethics. Great character all the way around.
Tell us more about this guy.
Well, he body/painted this
![]() One thing he won't do is detail a bed again. Or in other terms, he'll only do minimal body work inside a bed. Apparently once was enough. He's the new owner of VCM in Carson City. He's setting up starting next week. So I wouldn't call until then.
Just a thought contact local car clubs to see if they can recommend a shop.
#15 |
thanks to all... I'll check these guys out..
