11-03-2023, 10:25 PM | #1 |
are the radiator sizes for 350sbc and 454bbc the same?
Im having issues with overheating at stop and go traffic. I just bought a new thermostat and am planning on flushing the radiator out. the radiator looks really old so im thninking i may need to replace it. will a radiator from a truck with a 454 fit the location for a stock 350 truck? i found a few 454 trucks at a local pull a part.
11-04-2023, 12:51 AM | #2 |
Re: are the radiator sizes for 350sbc and 454bbc the same?
You will need not only the radiator but also the upper and lower mounts along with the shroud. I would grab the fan assembly also
11-04-2023, 01:21 PM | #3 |
The 454 was never offered in the 67-72 trucks so if you get a 454 radiator it will be a 73 and up which have different dimensions. Make sure you get a 4 row (or equivalent aluminum one if that's your preference) from the 67-72 era and like kwmech stated you will need to change the upper and lower radiator mounts from the 3 core to the 4 core which are a little longer.
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
11-09-2023, 11:43 AM | #4 |
Junior Member
On chevelles.com website, there's treasure trove of information on getting a bbc to run cool and a lot of the same things would also relate to a sbc. One gentleman, I think his last name is Wheaton(?) makes the argument about timing, fan positioning, what fan to use, fan clutch, shroud, coolant mixture, thermostat and other things.
I was having issues cooling a bbc in a 67 Camaro. I did the things he suggested and now I have no problem cooling a 489 bbc, that was dyno'd at 623hp. A lot of things go into keeping the engine running cool. In my situation, it was better (cheaper) to look at everything rather than just throwing parts at the issue. Just a thought.. |
11-09-2023, 02:37 PM | #5 | |
Who Changed This?
As for a replacement radiator, Cold Case makes a 2-row aluminum radiator that bolted right into my truck. It came with AC, so had a 4-row brass radiator already. Cold Case assures me that that radiator will cool all the way to 500 CI engines. I asked in case I decided to improve my pulling power by going bigger than the 400 BBC that's already in there.
11-09-2023, 03:08 PM | #6 | ||
If the OP should run with an original replacement, best of luck to you I dropped four into my rebuild, could have been five, I'm real good at replacing these One drop was temporary for a trial fit on new tran cooler lines, wasn't about to make it permanent, sounded like a maraca. First two came from Summit, followed by Speedway...........Run. I ended up with what's supposed to be a great quality US radiator. I can say they're built heavy, perhaps more than original. They look exactly right, real nice finish, and they fit exactly right too, with one caveat. The filler in the last one they sent was installed wrong, the cap's ear barely scrapes the top radiator bracket. First US radiator fit perfectly, but it leaked. They acted surprised, and really, I was too. They were *(&^)^ the filler was installed wrong, said they'd send another produced by the A-team, but I didn't pursue it. This one doesn't leak, and after doing this 3.5 times already............ To do over again, might serve someone well if a local can build one. I found a place 30 miles from me, after the fact. Quote:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-09-2023 at 03:25 PM. |
11-09-2023, 04:00 PM | #7 | |
Who Changed This?
