11-04-2023, 10:47 PM | #1 |
POWER STEERING for 1960-66 Trucks - a DIY for the 230, 250 and 283 engines.
Ever wanted power steering for your 1960-66 C10 but just weren’t sure what all was involved? Here you go!
I just finished this DIY LINK HERE . I really hope you like it. I was motivated to document how it can be done with fairly simple tools. It’s a one day job if you have all the parts. The methods I use have two benefits. 1. I didn’t actually have to remove my steering column. Just had to remove the steering wheel and steering shaft. 2. By “clocking the pitman arm” I was able to retain full turns of the steering wheel in both directions without adjusting the tie rods. That saved me the cost and trouble of an alignment. Here are a few teaser pics. The DIY has 175 photos. Haha! Can you believe it?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
11-04-2023, 11:07 PM | #2 |
Re: POWER STEERING for 1960-66 Trucks - a DIY for the 230, 250 and 283 engines.
looks like a fun project . . .
dont want to hear excuses, i want to hear solution(s) |
11-05-2023, 04:42 AM | #3 |
An incredibly great job,
your previous documentations have helped me a lot with my restoration, this one is great. Thank you for sharing it with us
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
11-05-2023, 09:10 AM | #4 |
Active Member
Awesome write up as this is on my to do list and these instructions (especially the parts list) will be very helpful. Thanks for taking the time to document and post it!!
11-05-2023, 09:59 AM | #5 |
Have followed your website on several how-to's for a few years now, awesome info.
1964 C10 Rusto-mod 5.3L - L59 |
11-05-2023, 03:51 PM | #6 |
Thank you for providing an exceptionally detailed tutorial for this power steering upgrade. I have a 1965 C30 with a 292 that I will be attempting to convert to power steering. I have always wondered how the offset of the new power steering box from the frame would affect the geometry of the steering linkage and the centering of the gears in the steering box. It seems that you recognized this, and addressed the issue by grinding the splines on the output of the steering box to accomodate that. Do you think that a person could have taken a small triangal file and filed 4 splines into the flat areas on the pitman arm? I suppose it is 6 of one and half a dozen of another. Also, because the steering shaft does not line up with the power steering box, you added a u-joint to the input steering shaft. It seems that the rag joint now acts as a second u-joint. I am wondering if a second u-joint could have been added in-line thus taking any flexing out of the rag joint? Any thoughts about my two questions?
Thank you again for an excellent write-up! Chris. |
11-05-2023, 06:31 PM | #7 | |||
I have some old school hot rod mechanic friends who suggested the spline delete. I gotta say it’s better and cheaper than adjusting the tie rods. No alignment needed. Quote:
One idea is to remove the rag joint and flanges from the Squarebody telescoping lower shaft. That should leave you with the round section at the bottom half of the telescoping shaft and it should have a 3/4” round ID. Then weld a 3” piece of the discarded 3/4” round factory shaft to a 30 spline U-joint. Insert the other end into the round portion of the telescoping shaft and weld in place. Now you have 2 U-joints and the shaft will still telescope if needed.
11-19-2023, 10:46 AM | #8 |
Just finished installing PS in a friend’s 1965 C10. Decided to “clock” the position of the pitman arm by cutting grooves in the pitman arm. The 4 flat areas were cut with hand files. Took about 30 minutes. Worked great and allowed us the position the pitman arm anywhere we wanted.
11-21-2023, 08:35 PM | #9 |
Nice work on the splines!
11-21-2023, 09:20 PM | #10 |
This past weekend I helped my friend install a power steering box on his 1965 C10 truck. We decided to cut new splines inside the pitman arm by running a V file on the 4 high flat spots. This method allows you to clock the pitman arm to ANY position. Takes a steady hand and precision and about 30 minutes with some good files.
