V8 motor mount concerns
Getting ready to drop a mostly new v8 and tkx into my 66 c10 replacing the 250 and sm420 and a bit of worry crept into my brain. After looking at old posts here I found I can reuse the old perches in the rear location on the v8 so cool beans there. I removed the bellhousing crossmember that cradled the 4 speed because the tremec tkx will be getting a new one of its own and it struck me.... Yeah these trucks came through with V8's but not with the torque and hp I'm hoping to get and only being anchored in by the front mounts and trans mount.
![]() Join Date: Sep 2020
Re: V8 motor mount concerns
The early muscle cars were the same system you’re going to…if you feel your gonna have more hp/torque than the big block Camaro and Chevelle then put the rear block mounts on…the motor mounts used then were insulated rubber but had an interlocking metal system the wouldn’t separate it they failed…a good parts guy will know what your looking for….
Wont a 66 c10 auto trans mount work? Plenty of room to move forwards or back. I wouldnt put a Tremec in it and mount it at the bellhousing.
MT65 what are the "block mounts" you are referring to? |
Block mount being the bellhousing mount, the forward mounts would be the ones that I was describing, the forward mount and the transmission mount would work fine, yes hanging a tremec off the bellhousing would be disastrous
The auto transmission mount may need a little modification, but that would be fine…my bad, didn’t read entire post….
#6 | |
Is this the style big block mounts you suggested? Little more pricy but worth the piece of mind Last edited by Chevy nutcase; 11-07-2023 at 03:28 PM. |
No, those are not what I meant, they would be the motor mounts for the high horsepower factory muscle cars, Camaro, Chevelle, Corvette…that looks like the rear bellhousing cushions for the stock C-10 stuff.
Finda good parts guy and he can get you the correct stuff, these new “I need your VIN number “ people are oblivious to situation you’re in…basically they don’t know squat… |
