Old 11-20-2023, 11:50 PM   #1
custom10nut
custom10nut's Avatar
1970 Grille question.
What is the color/shade of the Silver that’s on the lead edge of the 70 Grille Insert?
Is it Argent Silver?
custom10nut is offline   Reply With Quote
Old 11-20-2023, 11:57 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1970 Grille question.
Is the insert metal or plastic? I believe both types exist. Mine's plastic (repro) and appears to be painted argent.
~Steven
Simi Valley, CA
Old 11-21-2023, 02:04 AM   #3
custom10nut
Mine is the factory original, and it’s plastic.
I think you’re right on the color being Argent Silver
Old 11-21-2023, 08:39 AM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1970 Grille question.
The only "silver" I'm aware of on factory built units are the horizontal raised bars that were "silver" or "argent".
When I get to that point on my 1970 Blazer's grille, I'm going to color the horizontal raised bars with this:
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-21-2023, 10:18 AM   #5
HalfBrit
Those 2 pics (of the grill) you posted highlight the only thing that bugs me about replacement outer grills: Original - the horizontal lines continue to the headlight buckets. Replacement - the same lines stop at the parking light.
HalfBrit is offline   Reply With Quote
Old 11-21-2023, 10:33 AM   #6
LNP
Was the 69 the same as this with the silver on the insert?
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 11-21-2023, 10:51 AM   #7
1970cstblazer
OEM GM dealer replacement outer grilles 3985054 have been that way since June, 1971.
For some reason not easily explained, GM discontinued outer grille 3980036 in favor of the slightly different 3985054, which is what the reproductions were patterned after. Its super easy to spot an assembly line used grille on these.
The NOS grille going on my 1970 is an old one-box is dated June 1978, and unfortunately it is the second design that does not have the black extending all of the way to the satin black steel headlamp bezels/doors.
Also a note on the satin black steel 1969-70 headlight bezels/doors. GM discontinued them very early on in favor for the bright aluminum bezels that were original equipment on all 1971-72 trucks/Blazers/Suburbans. I think the later aluminum bezels/doors look terrible on the 1969-1970's.
3937473 LH changed to 3990705 in 8/1971
3937474 RH changed to 3990706 in 12/1971
Old 11-25-2023, 02:58 AM   #8
Richard
The replacement grill insert that I obtained years ago and you got from me is plastic like the original is entirely argent silver. It has the raised sections which I understand newer replacements do not (correct me if wrong). I am not sure which year 69 or 70 the grill was black with the raised sections in silver. With some time and patience you could mask off the raised sections and paint the rest black if you so desire.
Richard
Old 11-25-2023, 07:43 AM   #9
HalfBrit
Sometime in the late 90's or early 00's, I obtained my 3985054 (thanks 1970cstblazer) outer grill and the replacement inner grill after some front end damage on the highway. Comprehensive coverage is a wonderful thing
The full grid section on that inner grill (3985056?) is also completely argent silver, with the surround being black.
Old 11-25-2023, 08:11 AM   #10
1970cstblazer
Most of the replacement 3985056 inner plastic grilles are painted totally wrong from GM. They have to be either stripped, or reshot, then paint the raised bars.
Old 11-25-2023, 11:32 AM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
Right, I see the raised sections. But taking it off, doing the paint work and putting it back on is not likely to happen in my lifetime.
~Steven
Simi Valley, CA
Old 11-24-2023, 10:39 PM   #12
Nh4clo4
Nh4clo4's Avatar
On my grille, I repaired the black plastic, painted it black base coat, then used silver high performance silver metallic vinyl, cut into 1/8” strips, then shot a satin clear over the vinyl and base coat.
There didn’t seem to be a good way to get the silver consistent in paint.
Ed
Nh4clo4 is offline   Reply With Quote
Old 03-11-2024, 09:02 AM   #13
GM never had a 70 replacement inner grill. All replacements are 69 inner grills. Thus they all came in th silverish color.
Old 03-11-2024, 09:29 AM   #14
1970cstblazer
GM never had a 70 replacement inner grill. All replacements are 69 inner grills. Thus they all came in the silverish color.
Not exactly totally correct. Your statement is valid from August, 1971 to present per GM parts history books.
GM # 3980037 changed to 3985056 in 8/1971.
Before that GM # 3937301 changed to 3980037 in 7/1970.
Old 03-11-2024, 10:25 AM   #15
1970cstblazer
Doing more research on this, it appears that GM 3985056 are actually 1970 grilles painted like the 1969 grilles. Note the raised bars in this photo:
The assembly line 1969 grilles don't have those raised horizontal bars.
Old 03-11-2024, 10:23 PM   #16
cericd
cericd's Avatar
This statement is incorrect. I purchased a NOS 1970 grille off ebay in 2015 and it was indeed made of unpainted black plastic except for the silver (painted) raised lines. Unfortunately it arrived damaged so I didn't keep it. Here is a pic of the damaged area and a pic of the grille with its original GM box which I posted back in 2015.
I'm not sure how long Gm offered these but it must not have been long since they are so hard to find now. As far as aftermarket, I have only seen them offered with the whole center area silver. However, they have the raised areas like the 1970 oem inner grilles (but the raised areas are not 100 percent identical to the oem 1970 grilles). I don't think that the oem 1969 grilles had the raised areas (see this post by member FirstOwner69 regarding the oem 69 inner grille.) This has all been covered in various threads on the forum over the years. Here are some more examples of other NOS 1970 grilles.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-11-2024, 11:09 AM   #17
Thanks for info. That was stuff I got from a GM parts dept guy who is also into 67-72 trucks.
Old 03-11-2024, 10:37 PM   #18
cericd
cericd's Avatar
Here is a thread from 2020 in which member IronCanine illustrates the differences between an OEM 1970 iiner grille and an aftermarket 69/70 one and how he dealt with it on his beautiful 1970 Blazer restoration. His info starts at post #10 of the thread.
Chris
Old 04-10-2024, 08:11 AM   #19
1970cstblazer
Arrow Re: 1970 Grille question.
I just rebuilt the grille on my 1970 Blazer using NOS parts such as the parking lamp lenses, hood bumpers, headlamp doors, and outer grille shell. I reused the inner plastic grille, all bracketry, T3 headlamp bulbs, the parking lamp housings, and hood latch. I sourced the grille mounting fasteners from AMK Products.
I used the Molotow large tipped chrome pen for the raised bars, after refinishing the grille with Eastwood under hood black.
The reproduction 3944896 and 9428882 1969-1970 grille retaining fasteners from AMK:
https://www.amkproducts.com/bulk-fas...oduct_ID=15036
https://www.amkproducts.com/search-result/?ser=9428882
Old 04-13-2024, 08:54 PM   #20
zicc1835
zicc1835's Avatar
subd
zicc1835 is offline   Reply With Quote
Old 02-26-2025, 01:27 PM   #21
1970cstblazer
My project 1970 K20 came with an assembly line correct inner plastic grille 3985056. Box is dated 1978.
Old 02-27-2025, 12:42 PM   #22
70STOVEBOLT
70STOVEBOLT's Avatar
Does the GM/NOS inner grille have a part number on it?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-28-2025, 08:15 AM   #23
1970cstblazer
Red face Re: 1970 Grille question.
I examined every square inch of it, and could not locate any numbers or other identifying markings. Also, the silver details are very sloppy. I will have to re-do them with the chrome pen. There is a lot of casting flash on this part too. However, It seems to fit the outer grille shell perfectly.
Old 02-28-2025, 12:09 PM   #24
70STOVEBOLT
The reason I ask is, I bought an "NOS" inner from a board member several years ago and it didn't have any numbers on it. He listed it as part number 3985056 but it was painted like a 1969 grille.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-27-2025, 10:14 PM   #25
HalfBrit
The inner grill is part #3985056, as referred to in post #29. I have that same one and will probably paint it black, then detail the raised sections, as shown earlier in the discussion.
