Thermostat temps
Long story short I live in Arizona and recently changed my thermostat from a 160 to a 180 high flow speedway degree thermostat. I burp the coolant and at idle it's between 180 to 190 degrees. When I drive and stopped at a red light it will jump to 210. I'm thinking I still need to purge the system or is the new 180 thermostat the problem? Or a faulty temperature sending unit? I run dual radiator fans that come on at 180. Before with the 160 degree thermostat it would get up to temperature kinda quick but didn't have a issue at a red light. Any information will be GREATLY appreciated.
Thanks Chris Last edited by CSchmidt; 12-17-2023 at 04:18 PM. |
Re: Thermostat temps
Might be the start of a water pump issue. Loose belt? Cavitation?
Have you drilled your thermostat?
"If it ain't broken, fix it 'till it is!" |
Who Changed This?
![]() Join Date: Jan 2013
Perhaps the flow rate is the culprit, given that the old thermostat wasn't high flow(?). My truck had issues with heating for decades, until a high flow rate thermostat was installed.
![]() Join Date: Jan 2003
Ac or no ac?
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
The thermostat doesn't regulate temp. It just opens at the stated temp.
What???
72 C10 lwb fleetside -stock 350/350 combo |
#8 | |
Lighten up Frances. Last edited by franken; 12-19-2023 at 01:23 AM. |
The OP seems to think that the thermostat has something to do with the temp getting to 210--it doesn't. Once the temp gets above the opening point, the thermostat opens and as long as the temp remains above that point, it has no impact on cooling.
People sometimes think the thermostat keeps the temp at it's rating, which it doesn't and isn't the purpose of the thermostat. |
#10 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
With a 180F tstat and the engine is running at 210F, how is the tstat regulating? It's wide open and out of the loop. And of course it allows the engine to reach operating temperature quicker because at less than 180F it's inhibiting the flow of coolant through the radiator until it opens. That's what it is for.
Franken is absolutely correct. |
The thermostat opens at and above stated temp and closes below stated temp. which (if the rest of your cooling system is up to the task) fully regulates the temp of your engine.
____________________________________ |
#13 | |
Editing to say that if you were to run NO thermostat and the rest of your cooling system was functioning properly, the most likely thing to happen would be it would take longer to reach operating temp and in some cases the engine would never reach operation temp, and in fewer cases running no thermostat can cause overheating due to the speed at which the coolant is flowing through the system, not allowing time for the coolant to cool in the radiator.
i too live in phx.
every late model vheicle has around a 200 t hermostat Post a few pics of your set up. Its 60 degrees out nealry daily, are you over heating? what happens when its 118 degrees out? you might just be having the 'i cant stop looking at the guage' syndrome instead of enjoying the driving experinces..
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 1963 Scout Retro-mod https://67-72chevytrucks.com/vboard/...d.php?t=854167 |
#15 | |
What temp did the truck run at before? Is the thermostat the only part you changed? Can you adjust the temp that your fans come on at? You need to make sure the system is fully purged before trying anything else.
#16 |
Yeah i only changed the thermostat. I went from a 160 to a 180 thermostat. Thinking I had a 180 all along I might go back to 160. I thought my thermostat was sticking open or closed cause it got to temp kinda quick thats why i switchedit out. I tried purging the system a couple of times without success but I don't have the right funnel. I drove the truck without a thermostat last week and it didn't overheat stayed between 170 and 180. It just started overheating with the higher 180 thermostat. Didn't have any issues with the 160 in the summer time. Will get hot at a traffic light but goes down when I drive again. Water pump is fairly new. Thanks.
#17 |
![]() Join Date: Feb 2016
A thermostat will never cause an engine to heat up faster. The thermostat only reacts to coolant temperature. It won't add heat to the coolant
The thermostat should be closed when the coolant is below the rated temperature of the thermostat. The job of a thermostat isn't to keep the engine from overheating, that's the radiators job, the thermostat is there to regulate the coolant flow, so the engine stays in its most efficient temperature range. The thermostat does its best work when it is cold outside. However because thermostat is not an off on switch it may take 5 or 10 degrees of temperature change to get the thermostat to completely open (or close). So it may be rated for 180 degrees but it could start opening at 175 or 184. If the thermostat is stuck open it could cause the engine to take longer to reach operating temperature. As previously stated you may need a high flow thermostat. As inadequate flow may cause the engine to run warm. This would be noticed when driving on the highway in hot weather or when the engine is heavily loaded for extended periods The rule of thumb for temperature creeping up at idle is caused by not enough cool air flowing through the radiator. Whether that is from blocked fins in the radiator or insufficient draw by the fan or hot air being recycled from under the engine to the front of the radiator. (3rd gen F-bodies suffered from this if the small air dam under the radiator got torn off or removed). In hot weather being too close to the car in front of you at the traffic light of can cause the engine temperature to rise, if the vehicle in front of you has their exhaust feeding directly into your radiator.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#18 |
In all reality 210 isn't that bad, not close to overheating, so not too much to worry about there. I'd still be a little concerned about the temp jump at red lights. Not sure why changing thermostats would change things, unless you got a bum one....which is more and more common these days. What's the condition of the other cooling system components? Where's the temp gauge sending unit plugged in at? Where's the vacuum advance hooked up at? Where's the thermostat for the fans hooked up at? I'd have the fans come on at 170 with a 180 stat. When you refilled the radiator and tried to purge it, did you also fill the engine through the theromstat hole?
#19 |
![]() Join Date: Feb 2022
If you are getting a moderately correct temps while running at speed, and heating up at idle at a stop light I am inclined to think it is something to do with the fans. You have two fans. Are both running? Is it possible you bumped one of the leads when installing the Tstat. I had a issue with my fans a while back. The connectors do not have a catch tab on them and will wiggle loose but not completely disengage. That will compromise the amperage to the fan. It will slow the fan, eventually overheat and damage. You will eventually start popping fuses. Make sure both fans are running strong. Champion sells replacements at a reasonable price.
The other idea, is the stat in correct orientation, and have you tried switching back to the original just to be sure the new stat is not causing the issue? |
#20 |
Fans and Radiator are champion brand and are fairly new like 2 years old. I did go back to 160 thermostat and is driving good and not overheating bit am I using the right TempStat? With my fans?
Also will move temp sending unit to block and see what happens but might be after the holidays. |
#21 | |||
"I ain't nobody, dork."
![]() Gary
#22 |
i dont know where you live.
But go get on loop 101 and drive 15 miles one way, tunr around and go back home. For those not in PHX, loop 101 usually runs about 75 mph constanlty, up to like 95 mph. a good 15 mile drive will get your engine up to operating temp and at around 75 mph there is no need for any fans to be on. This will completley stabilize your engine temp. -what does the engine temp gauge read while driving this distance? This test will tell you hw efficient your system is while driving. -now be aware, on my v8 s10, i would overheat above 65 mph. What i found out is i had a bubble form under my truck in the engine compartment and no cool air was going through my rad. it was recirculating the air out of the rad under the truck and up into the rad again. If i slowed down, instant cool down to correct 200 temp.. i sped up to 70 itd heat up to 230 quickly. SO, for your truck, you have to do several tests to figure out what and where your issue is. Simplest is the freeway test. Report back and let us know what your temps at speed are. Dont drive 2 miles, go the full at least 15. When I do test runs, i go from my home i17 bell road up to cave creek and back. Thats almost a good two hour drive there and back, and roughly 30 miles one way.
#23 |
It's my water pump slowly going out. Purged the system again today and looked at the hoses really good and see some coolant coming from the seep hole on the water pump leaking onto the lower rad hose. Thanks for all of your suggests and support through this post.i appreciate it
Chris |
#24 |
In my 67 C20 with 402BBC TH400, I run 3 core radiator, 180 high flow stat, clutch fan, Shroud. I can Drive it a distance 20mi plus, it runs at 185F, sit and idle, will slowly creep up to 195, drive and its right back to 185. but ambient Temps are below 90deg F in Summer past 2 yr. Pleased with the cooling sys. Still have room for 4core, but may not need it, unless I was in TX, AZ. CA. high ambient...
My cooling system is basically OEM... no elec fans, no Alum rad, trans cooler in rad. It works as designed. Last edited by 1967GMCC20; 12-27-2023 at 10:36 PM. Reason: Note |
#25 |
Here are a few things to try: 1) Take the old thermostat and the new one and test them in boiling water with a thermometer. When the water hits 160, the old one should open. When it hits 180, the new one should open. If they both do, then it isn't the thermostat. 2) Check the radiator. I don't know how old it is, but could it be plugged? Usually a plugged radiator will make the vehicle run hot while cruising down the road, but will idle at normal temps. 3) Collapsed hose? Rare, but it happens. Usually the lower hose because it is neglected the most. 4) Last, remove the overflow tube on the radiator and attach a piece of hose. Fill a beer bottle about half way with water and put the hose in the bottle in the water. Start the engine from cold and watch the bottle. You will get a few bursts of bubbles. This is the thermostat opening and closing until the engine get to temp. After that, is should stop. If it does not, you have an engine problem, most likely a blown head gasket and it is allowing gasses to enter the cooling system.
