Old 12-24-2023, 03:41 PM   #1
BIG ORANGE
BIG ORANGE's Avatar
Custom intermediate steering shaft idear's
Looking for something other than stock for 72 1/2 ton chevy.....
Any idear's guys?
Vendors, price, availability
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 12-24-2023, 04:07 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Custom intermediate steering shaft idear's
Speedway Motors has a lot of custom stuff like that.
Couplers: https://www.speedwaymotors.com/shop/...4-15-574-31187
Shafts and Joints: https://www.speedwaymotors.com/shop/...s~38-47-15-574
84 Chevy K-20
Old 12-24-2023, 04:19 PM   #3
YBNORML
YBNORML's Avatar
Any idear's guys?
Just went through this on my 67’ project.
I upgraded to an aftermarket box that has a different spline count than original.
Double D bar and 2 u joints. It was pretty simple. Both items are stainless steel. I also had to change columns since the 67/68 columns have in intermediate shaft.
The 18” DD bar was about $50 and the joint were $125 each. I just bought them at my local speed shop. I would imagine that they are available just about anywhere.
Ive been running the exact same setup on my 72’ Blazer for about 6 years with no issues.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 12-24-2023, 04:19 PM   #4
RustyPile
RustyPile's Avatar
Borgeson also has some good stuff. I have a couple of their items on my '71...
https://www.borgeson.com/?utm_source...C10%20Steering
RustyPile is online now   Reply With Quote
Old 12-24-2023, 04:20 PM   #5
RustyPile
RustyPile's Avatar
{EDIT}
Sorry.. I'm having issues with the site today.. Somehow this post showed up as a duplicate..
Old 12-24-2023, 06:23 PM   #6
Rick Bollinger
This looks like a really nice setup and I bet it works great. But it's not collapsible if you're in an accident that steering wheel has very little give as where the stock unit will collapse a few inches anyway.
Rick Bollinger is offline   Reply With Quote
Old 12-24-2023, 07:02 PM   #7
YBNORML
YBNORML's Avatar
You are correct as far as 69-72 goes. But in 67-68 the factory steering shaft is one continuous piece from wheel to rag joint. I’d love to use a collapsible shaft, but as far as im aware there is no aftermarket piece. Which means that every truck with an updated steering box or aftermarket column has a solid intermediate shaft. Are you aware of any other options?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 12-24-2023, 11:58 PM   #8
Rick Bollinger
My 68 has a collapsible one. As far as I know it is original but it may not be. It is at least a oem shaft. My truck had a lot of damage done at one time. Back half of frame replaced and back of cab has been cut and replaced at some time. Must have been in a pretty bad rear ender. Maybe the steering shaft was replaced as well. It is the type where it has the rag joint at the bottom collapsible shaft and flexible joint at the top where it bolts to steering column.
Old 12-25-2023, 12:07 AM   #9
jnd
New Member
I installed this in our 1969 C20.
http://www.borgeson.com/18-collapsible-shaft
jnd is offline   Reply With Quote
Old 12-25-2023, 08:49 AM   #10
Borgeson is the best way to go if you're getting away from stock
Old 12-25-2023, 04:35 PM   #11
ghackett1
68 C10 Longbed
ghackett1's Avatar
I have an intermediate shaft for a 72 if that will help you. I also have the 3/4” intermediate which will work in the 67 & 68.
ghackett1 is offline   Reply With Quote
Old 12-29-2023, 09:54 PM   #12
BIG ORANGE
BIG ORANGE's Avatar
Well if you do have one I'm interested, post pictures please....
Old 12-29-2023, 10:41 PM   #13
raggedjim
raggedjim's Avatar
The square body guys are using xj jeep intermediate shafts (some are using astro van shafts). I'm thinking any 3/4" shaft with the 36 spline coupler could be adapted to work but I have never tried it (yet).
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 12-30-2023, 07:48 AM   #14
adf5565
I just built one of these out of borgeson u-joints/telescoping shaft. Here are the part numbers, only difference you may have is that my steering box is a red head which is 13/16 spline vs 3/4 which is believe was stock. So you may have to adjust accordingly but it is easy to find on summit. Shaft is easy to trim to size.
BRG-450024 shaft
BRG-033452 upper u-joint with damper
BRG-014940 lower U-joint
adf5565 is offline   Reply With Quote
